Question about Smartpool Pool & Spa
Scrubber 60 Plus. Why does the bag keep coming off while it's running?
Posted by Tracey Lisiecki on
My Nitro cleaner pump/fan motor jerks every 3-4 seconds and the fan turns a few degrees. Nothing more happens. What is wrong?
The fan is an indicator of the main drive motor...so if the fan is debris-free...then you've got a motor problem. Since you can't get replacement parts, you'll have to replace the main motor unit...around $200 with shipping. I've replaced mine, it's a relatively simple process for the DIY guy...and it extends the life of your nitro significantly. If you get three seasons out of your motor, you are doing good...anything more is lucky, anything less means you probably mistreated the little guy...like leaving it in the pool non-stop, or allowing it to run out of the pool which will quickly end the main drive motor life.
Jun 28, 2015 | Smartpool Nitro Robotic Cleaner and Caddy
I have dried on grease stains on the bottom of my pots and also there is a whitish colored film that remains after the pots are washed and dried. I need to know how to clean them.
Spray Oven Cleaner all over stains, SEAL inside plastic garbage bag, leave bag for 2 days, wash pans with scrubber pad, stains should be soft and come off with a little rubbing.
Nov 20, 2010 | Microwave Ovens
Need to order new bag,where, how.
The SmartPool website has an option for entering your zip code and finding a dealer/repair service in your area. They will carry replacement parts for this pool cleaner.
http://www.smartpool.com/website/#
Aug 01, 2010 | Smartpool Dolphin Robo - Kleen Above...
My Nitro wallclimber floats on the surface and will not sink to the bottom of the pool
The most likely cause is air trapped in the debris bag. Remove the bottom panel with bag. Submerge the cleaner and replace the bag underwater. Also see Smartpool's trouble shooting guide for further assistance. http://www.smartpool.com/website/manuals/NC51%20Troubleshooting.pdf
Mar 09, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
Pool & Spa Logo
53 people viewed this question
Top Smartpool Pool & Spa Experts
Marvin
Marvin
David Spradling
David Spradling
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
