Question about Health & Beauty
I can not reset my scale it is model # CR6331, I put in a new battery but now I can not reset it back to lbs.
Posted by Bobbie Brooks on
5 Related Answers
Anonymous
SOURCE: weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Posted on Aug 25, 2008
Anonymous
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
rk_smith
  • 39 Answers
SOURCE: How do I change the setting from KG (currently
There is a switch on the base of the scales that you can change over to set Lbs or Kgs.
Posted on Feb 02, 2010
Anonymous
  • 86 Answers
SOURCE: my scale reads 0.0.0 st-lb how do i put it back
press buttons on it or get new instructions
Posted on Feb 20, 2010
Anonymous
SOURCE: E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Posted on Jul 28, 2010
Undefined
Most likely the old battery was so low the scale was reading low.
Oct 13, 2014 | Health & Beauty
SCALE READS 20 LBS TO HEAVY HOW DO I CALEBRATE
Sounds like reset access points. Try pressing something in the hole gently to see if you can hear it clicking a switch...if it does the hold the button in and turn th scales on or turn the scales on and the press the reset. Good luck
Nov 24, 2013 | Healthometer Health o meter Glass Digital...
I got a addoer twist scale model number CR6331 and i need to know how to use it
I lost my set up manual and need to set scale back to zero.
Mar 25, 2012 | Health & Beauty
Instructions for body fat scale CR6331
how do i change kg to lb on my body analyzing scale
Jan 13, 2012 | Home
Change scale from kg to lbs
Ok i Just figured it out my self with no manual. When you put new batteries in your scales the unit will be shut off. Press and hold the select button for 5 seconds and then it will show LBS or KG and you will be able to change your weight at that time. Hope this helps.
Apr 23, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
Scales are getting a Err 1 message, installed new batteries, need to reset them some how. They will not zero themselves out
My scale was fine the other day. I weighed myself earlier in the day. I tried to weigh myself later in the day and the scale started reading ERR1. I called Taylor and they had me try to "reset" the scale twice. It did not work.
The steps for resetting it are:
Turn the scale over
Remove the batteries for at least 10 seconds
With the scale on it's side (even though you aren't supposed to put the scale on it's side, carefully insert the batteries and put the back on the scale
Slowly return the scale to a flat hard surface
Step on the scale after about 10 seconds of it being back in position
If the scale still jumps with crazy numbers and reads ERR1 try to reset the scale again being very careful when the scale is on it's side
If this does not correct the problem then the scale will need to be returned to the manufacturer, to the address on the label on the bottom of the scale
I was told you could put the scale in any box and ship it to them the cheapest way possible but be sure to keep the batteries with you
If you are still under the year warranty they will send you out a new scale in 4-6 weeks
I was not happy that my scale was purchased on 11/14/09 and it died on 02/12/10. Luckily I knew where my receipt was. I pulled it out and noticed 02/12/10 was the last date to make returns to Target for that transaction. I was able to go and return my scale to the store because it was in the 90-day window that I had purchased it.
I was told that the reason the scale was doing this was either an delayed electrical interference that may have occurred during. The only other reason I was given was an OVERLOAD. Well, I seriously doubt an overload was my issue. First of all I was the only person at home that day so nobody else stood on the scale. I had used it earlier in the day and it was accurate. I am 5'6" and 139 lbs. so I seriously doubt it was OVERLOAD unless someone isn't telling me something and I need to lose some serious weight.
Anyway, I hope this helps. I wasted a lot of time trying to figure it out that day. Now I have my new receipt and if this happens again I will go get my new scale just as I did this time. I thought a 4-6 week wait for a replacement scale was insane. Kudos to Target for taking the scale back without a box or instructions on the last day I was able to make a return.
Feb 09, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
The Homedics SC 380 scale said low battery. After the battery (3V DL 2032) was replaced nothing works (does not turn on). Why would this happen? Is there a reset button or a button that turns it back on?
The same happened with me, but here is what I did and it worked. I took the new battery out and set the setting on the bottom of the scale to Stone, put the battery back in. Now when I put the battery back in I made sure the plus on the battery was the last part to go in, it faced the part inside the casing that needs to be pushed back when you take out the battery. Once it was in I put the setting back to LBs and it worked. Don't know how but I was just as frustrated and it worked.
Jan 28, 2010 | Homedics Health & Beauty
Taylor 7530 scale wont turn on,i have new batteries
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
Dec 18, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Weight watcher scale not calibrating weight correctly
Aug 12, 2008 | Irons
Health & Beauty Logo
60 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
