Question about Samsung Audio Players & Recorders
I have a bose 321 system and i lost the remote i also havea samsung bn59 00599a remote control what codes and how do i get the samsung to workwith the bose 321
Posted by Jason Hendon on
Simon Atkinson
  • Samsung Master
  • 1,706 Answers
It would be simpler to buy a new remote for the 321 system. Spares for this system are not very expensive. A remote will probably cost less than £20.
Posted on May 01, 2020
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Posted on Jan 03, 2008
Anonymous
SOURCE: Bose 321 Remote not working
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Posted on Jul 04, 2008
Anonymous
  • 71 Answers
SOURCE: how do i get my playstation 3 to connect to my bose 321 system?
Very simple. Red and White RCAs into any available input on the back of the 321. If the PS3 A/V cable can't separate the audio from the video (yellow RCA) by length of cable then get an RCA extension.
You can also connect this digitally with an optical cable (better sound) but you need to assign the optical cable to an input from your system menu. Your system menu can only be displayed on the TV from the video out of the 321. Go to "media center" and then down to "optical source"
Posted on May 31, 2009
Anonymous
  • 71 Answers
SOURCE: I put in a dvd and i get format not supported?bose 321 gsx system
-If this happens on all DVDs, then this may need to be repaired (Bose will repair this for free if this is the case- they can test it too) -If this happens on some or most DVDs, you can try a firmware update. Call Bose at 800-367-4008 and tell them about this. Request the most recent software/firmware update disc.
If you haven't already, just try resetting this first. (unplug the power cord from the acoustimass module for about 30+ seconds and try again)
If this happens primarily on rentals or home-made dvds, an update will most likely fix the problem.
Posted on Jul 17, 2009
Anonymous
SOURCE: My Bose 321 series II is not responding to the
Replace the batteries from the remote control. Press and hold the TV button on remote for 5 seconds. If the red light shines bright, your remote is OK since it is showing it's programmable side. If unit still won't go on using the remote, reboot the whole system by unplugging the power cord and other wire from the Subwoofer. Wait one minute, then replug all and see if the system displays BOSE 321 in front when re-connected. If so, try the remote and if that doesn't work, your dead, the Infra red communication device from the unit to the remote is busted inside the unit and needs to be returned to the company like mine!!!!!
Posted on Dec 15, 2009
I lost my Bose 321 remote I have a Sony RM-YD010 and can't find the correct code to use this last remote for my Bose system. I have tried many codes suggested and nothing works. Help. Thanks
BOSE Uses different type of protocol in their remote . You will not be able to program any remote for your bose system. So try to buy its original remote.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 14, 2016 | Sony Televison & Video
Bose 321 device code for Kogan UHD TV
Your Bose remote may not work with your Kogan TV.
Aug 12, 2016 | Bose 321 GS series II
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
My boss 321 remote control will not work with my apex TV.
Setup codes for Apex with Bose universal remote control are: 10156, 10748, 10879,10890, 11217, 11943,11991. If you wand to know more codes to Bose brand remote controls, check this link.
Jan 22, 2013 | Televison & Video
Bose 321 series ii remote control
try remote on your tv...hold tv button till it lights up and enter code for tv till red led goes out...then try it on tv..if it works,then your ir reciever is kerput...not your remote.i am trying to find parts for mine as well.
Oct 01, 2012 | Bose (321GS) System
I have a 321 bose system, and I cant find the device code for my uverse reciever
there are 8 different versions of the 321 so the code is going to depend on what version you have. Motorola makes the boxes for uverse, so i would start there. some of the uverse boxes use newer codes then what is prestored in the Bose remote. you may have to use the uverse remote and program the Bose volume in it.
please rate if this was helpful!
Apr 07, 2011 | Bose (321GS) System
I have a Bose 321 GS III Cinema system. What code do I have to program in the Bose remote control to control my Motorola 1960 Cable tuner? The codes in the Bose manual do not work, so I expect that the...
having same problem with my bose 321 GSX. my mom just got shaw digital and likes the shaw remote better than the bose one. I can program the bose remote to do everything but can't seem to do it for the shaw remote. I think i need a code for bose as a reciever? I dunno... any help would be good eh!
Aug 10, 2010 | Bose (321GS) System
Bose 321 system stuck at 30 volume
Is vol buttons button on unit do the same, try remote.
If not try unplug from wall wait hour and try agian, if not bose update cd..
Aug 02, 2009 | Bose (321GS) System
Remote code
I have timewarner and programed my remote with code 1229 but it dosent support all functions. I can
run the dvd and the volume. Hope this will work for you.
Good luck finding more codes.
Dec 27, 2007 | Bose (321GS) System
54 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
