Question about Mitsubishi Televison & Video
HI, My mitsubishi WD-82740 tv has black and white verticle lines going across the screen (looks like a barcode). Is there a fix to this? I can send a picture if need be.
Posted by Matt Freeman on
  • Mitsubishi Master
  • 18,438 Answers
This can be either a bad TCON board or an LCD / LED screen failure. https://www.youtube.com/watch?v=6OPrb9Gdf9Y
Posted on May 01, 2020
Mitsubishi black lines on right bottom screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Aug 09, 2014 | Mitsubishi WD-73737 73 in. HD-Ready TV
WD82740
How can I clean the inside of the WD 82740 screen? There is a brownish soil spot about a foot in size and part of it kinda looks like a grid or tic tac toe board mark. HELP!!!
Feb 27, 2014 | Mitsubishi 82" WD82740 3D DLP 1080p...
Model: 52725 we hooked an xbox to this thing and it wont give us a clean picture, rather black and white fuzzies and has green lines shooting across the screen, sometimes purple going across the screen...
There are small surface mounted capacitors on the dm Board and the fmt board that have gone bad. They need to be replaced. Most tv techs will charge about $400 to do this.
Mar 16, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Our tv has several white spots blocking out the picture on the tv, what could be the issue?
This problems very exspensive to fix.The Light projection Engine have a problems,with a IC design flaw.This problems happen to many Big screen tvs 65 and up have a design IC flaw by many companies like Sony,Mitsubishi,Toshiba and Samsang.Call up Mitsubishi make some kind of deal with them to help u to fix the Light projection Engine by replacing the IC or replace the whole entire Light projection Egine.
Dec 08, 2010 | Mitsubishi WD-65731 65" HDTV
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Problems with my Mitsubishi hd1080
Most likely you are looking at conversion chip problem. The replacement price on these can varry widely. It may be cheeper to look into purchasing a flat panel lcd or plasma tv.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Have two Mitsubishi WD-62627 HDTV's. One will go all black and white after unit has been on a while; shutting it off and turning it back on will correct problem for a while. The second WD-62627 has seven...
The first one sounds like one of two bad boards. If you get color here always(component input (Y Pr Pb) then it's the terminal 2 PCB, and if not it could be FMT board. Either way you would need further checks to make sure. For the other set i would need email for instructions, because of broad range of problems!
Mar 12, 2008 | Televison & Video
Convergence Problem?
Convergence problems are what you have possibly a pincushion error. Either way if you have to have a repair shop do the repair, you should look at replacing the old TV.
Jan 26, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
