Sewing Machines Logo
Cathy Ezrailson Posted on Apr 30, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get a new foot pedal for a white 1740 sewing machine
Tom Chichester
Level 3:
Top Expert:
  • Sewing Machines Master 62,329 Answers
  • Posted on Dec 10, 2020
Tom Chichester
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
670725
Points
975369
From White, an appliance parts supplier, or a sewing machine repair shop
Www whitesewing com
Straight basting stitch (stitch width of 0 and stitch length of 4.)
1helpful
2answers
Grinding noise and needles breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
since there is a grinding noise it would be a good idea to have the
machine checked
1helpful
I need white sewing machine #1740 manual
Singer has the manuals for the White 1740 on their support site: http://www.singerco.com/accessories/instruction-manuals .
The direct links are:
http://www.singerco.com/uploads/download/712_white-1740-x.pdf and http://www.singerco.com/uploads/download/1105_white-1740-x.pdf . The two links seem to give identical files. Note you will need Adobe Reader or a similar program to read the files.
I hope this helps.
The small bar that holds the zipper foot on broke. How can I get a new zipper foot?
There will be several zipper feet available at any of the sewing machine stores. You can either take the broken foot with you (or another foot for the machine) or note the shank length and the bar length on the foot. I believe the White uses a low shank foot. In that case, you would get a foot that is designed as a low shank foot (assuming the bar isn't narrower than your current foot), and it will work.
The common Foot styles are low, high and slant.
I hope this helps.
(you can also order sewing machine feet online but you need to know the style of how the foot connects to the machine. The easiest way to do that is to compare it to similar feet in a local store. Most of the online vendors will list the machine brands that are compatible with a given foot. However, I know that Husqvarna low shank feet have changed width over the past 30 years and thus not all of the feet from a new machine are mutually compatible with those for an older machine. So I wouldn't guarantee the match without seeing the feet side by side.)
I have a white quilter's sewing machine, model 1740. I cannot get the foot pedal to work. It only sews if I push the start/stop button on front of machine. How do I get the foot pedal to work?
Hi, follow the instruction below to troubleshoot the foot pedal
  • Unplug the machine plug and wall plug on the sewing machine.
  • Check the power cord for cracks, burns, or faulty contacts as this could be a possible reason for the foot control not working.
  • Open the foot control by using a knife or flat surface tool, such as a flathead screwdriver, to pry open the corner of the foot control.
  • Check the wires to see if they are disconnected; this can happen if the foot control drops to the ground. To check wires, remove the circuit board using a flat knife. Inspect the wires inside the foot control. You will see some wires that are soldered together. Check to see if there are any broken wires, as this could be the problem. If the wire is broken, clean the area to remove any debris or dirt. Remove a small amount of the insulation before soldering. Solder wires together.
  • When you are done, reassemble the foot control and make sure it's working again.
Where do I buy parts for my 1740 White machine? I broke my clear foot and would like to get a replacement but I don't have a number or anyway to look for it.
try sewingpartsonline.com
look under white or singer sewing machines for the model number & if you can't find the model number email them & they will answer
2helpful
White 1600 SpeedyLock. Power, but foot pedal won't engage. Took foot pedal apart, mechanically looks fine-- computer board in there. Do I need a new foot pedal?
When stepping on the foot control, does the motor hum or anything? Or is dead silent? If it sounds like it's trying to do something, the serger probably needs to be serviced. If it's silent, you probably need a new foot control.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
