SOURCE: hooking tv to Bose radio
You need a pair of RCA cables.You might have some extra.First if you have a cable box or satellite box you must use a pair of rca's (3 cables, yellow, red, and white ends).If you have a digital cable or satellite box the on the back there will be rca outputs.use one of the rca cables and plug it into the output of the cable box to the INPUT of the Bose stereo(they will be labled) then on the OUTPUT of the Bose take another pair of RCA cables and plug them into the rca INPUTS on the TV then use the original remote to the TV and change the Input source the either AUX 1 or AUX 2 which ever aux you pluggen the cable into coming from the output on the Bose.If you do not have a digital Cable or Satellite box then you will need a Modulator.What this is ,is a small box that will convert the regular cable coming from the wall into those RVA cables that would plug into the INPUT of your Bose. you can get a modulator from walmart meijer radioshack...ect for about $20.Hope this helps,rate me if it does or leave more info.GOOD LUCK.
SOURCE: Bose Wave Radio w/single CD player on top
My Bose Wave Radio/CD developed this problem about a year ago. I don't use the CD player much and kept the unit clean. The disc spins but, the system does not read it. Cleaning the lens with cotton did not help.
Read that Bose charges $75 to fix this problem.
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
SOURCE: 2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
