Question about Mitsubishi Televison & Video
WD-82642 mitsubishi 83in 2pc front screen what order do they go in
Posted by kenneth smith on
Arnie Burke
  • Mitsubishi Master
  • 6,480 Answers
Xplain issue bettr..giv som details
Posted on Apr 29, 2020
Testimonial: "when i got this tv the 2 front screens had popped out frosted and darker with linticuler surface what order do they sit in ?? frosted to the inside and darker to the front ?? is there a diagram ANYwhere ??"
  • 1 more comment
  • kenneth smith
    kenneth smith Apr 30, 2020
    these are the Tracks the screens fit in just needing to kno which screen goes where
  • kenneth smith
    this is the top right hand corner looking down the track
  • kenneth smith
    another image looking straight down
1 Related Answer
digitaldump
  • 115 Answers
SOURCE: Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Posted on Sep 28, 2009
Mitsubishi WD-60638 firmware
Make sure software was in top menu in USB stick. Not ib a folder. Try reset buttons on front of TV. Could be bad e2p module. (boot firmware.)
Mar 30, 2014 | Mitsubishi WD-60638 DLP TV
Help to dry out screen
Try putting it into a bag of rice for a few days. Usually does the trick.
Dec 22, 2013 | Mitsubishi WD-82642 3D DLP Home Cinema TV
Screen is dim. Have brightness turned up to max setting. Does the lamp get dim with age? Mitsubishi WD-Y577 dlp rear projection tv
Yes... from the moment the lamp is put into service, it begins to deminish in brightness. You should order a replacement lamp to have on hand.
Mar 15, 2010 | Mitsubishi WD-Y577 Television
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
SCREEN-ASSY Removal
top).
on 62 inch models),
Aug 01, 2009 | Mitsubishi WD-65735 Television
Mirrors are broke on a mitsubishi wd 57731 57 hdtv
Mirror in the set-approx $75.00
Front Screen- approx $200.00
May 03, 2009 | Mitsubishi WD-57731 57" Projection HDTV
The screen seems dark and blurry
take off the front panel carefully, usually 2 screws around the controls. Next, stick your head in and look at the red green and blue tubes. see if they are dirty? if, not look further into the tube using aflaslight and see if there is a white pasty looking substance inside. IF so, you need to clean as you have bacteria growing in the cooling fluid. A big job and you need the gaskets, can order from Mitsubishi tech support..good luck be careful.
Mar 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62827 Problem
Uh Oh! Unless this is something simple like a loose piece inside the projection chamber shadowing the screen it would have to be the light engine ($$$) warping due to overheating of its plastic housing. Check inside the cabinet for loose objects in front of the lens, then clean all the fan filters, then call your warranty company.
Hope Ya Fix It!
Jan 15, 2008 | Mitsubishi WD-62827 62" Television
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
