Question about Measuring Tools & Sensors
Hello I have a 9630U-IT, I installed the batteries correctly but the station does not display humidity neither in and out temperature .
The indoors temperature (it shows an OF.L) outdoor nothing but reception okay. Humidity nothing but hour and sad face.
Posted by Mariadelmar Andrada on
Andrew Taylor
    Top Expert:
  • 33,969 Answers
First, insert the new batteries into the Temperature sensor. (see "Install and replace batteries in the Temperature sensor").
2.
Immediately after and within 30 seconds, insert the batteries into Weather station (see "Install
and replace batteries in the Weather station"). Once the batteries are in place, all segments of
the LCD will light up briefly. Following the time as 12:00 and the "Weather man" icon will be
displayed. If these are not displayed after 60 seconds, remove the batteries and wait for at least
10 seconds before reinserting them.
3.
After inserting the batteries, the Weather station will start receiving data from the sensor. The
outdoor temperature and the signal reception icon should then be displayed on the Weather
station. If this does not happen after 3 minutes, the batteries will need to be removed from both
units and reset from step 1.
4.
In order to ensure sufficient 915 MHz transmission however, this should under good conditions
be a distance no more than 100 meters between the final position of the Weather Station and the
sensor (see notes on "Mounting" and "915 MHz Reception").
Note:
If the signal reception is not successful on the first frequency (915MHz) for 45 seconds, the
frequency is changed to 920MHz and the learning is tried another 45 seconds. If still not....
and about the Sad Face
Comfortable:A happy face icon "(68°F to 78.6°F)and relative humidity reading between 45% and 65%.Uncomfortable:A sad face icon " " indicating any value outside the comfortable range
https://www.manualslib.com/manual/516303/La-Crosse-Technology-Ws-9630u-It-Ca.html?page=7#manual
Posted on Apr 29, 2020
Testimonial: "Yes I got all this info in the instructiones but after doing it correctly several times it does not show any temperature or humedity in the display. Time and the rest seams to be ok. what can the problem be? I tougth about the outdore sensor but the inside temperature does not show neider. can you help me more??"
  • Andrew Taylor
    Andrew Taylor Apr 29, 2020
    Only to try again with brand new Duracell batteries out of a new packet freshly brought form the store, and not a Dollar Store counterfeit. These unit are pretty trouble free, but the batteries do have to be inserted in the correct order and quickly.
    My unit takes coin cell batteries and is very heavy on them, 6 months if I am lucky. The first thing to go is the outdoor temperature, but the outside sensor battery is fine, it is low voltage on the inside unit, not being able to talk to the outside one.
My 6yo NatGeo super weather station has quit transmitting outdoor temp & humidity info. The display is present and correct for all other categories. Changed batteries, no help. Any ideas?
  • Remove all batteries
  • Install batteries in transmitter and wait for it to begin sending data
  • Install batteries in receiver. You should see temperature and humidity displayed
Jul 18, 2017 | Measuring Tools & Sensors
How to set up taylor `model 1731
  • Indoor (32°-122°F/0°-50°C) and outdoor (-4°-140°F/-20°-60°C) temperatures. Lower outdoor temperatures achievable with lithium batteries; Indoor and outdoor humidity. Includes temperature and humidity trend indicators; Daily min/max recall for temperature and humidity. Features a calendar and clock with alarm; The wireless remote sensor transmits up to 200 ft. The base station and wireless remote require 2 AAA batteries each, not include. If you want essay related topic you can go for custom essay writing service will get better result.
New Generation Custom Essay Writing Service with Intelligence EssayCaptains
Feb 06, 2017 | Taylor Health & Beauty
My Smart Gear STG-6007-BB weather station won't pick up the outdoor temperature from the remote sensor. I changed the batteries and reset the unit, but it still doesn't work. Any suggestions?
  • Install batteries in remote sensor. Allow time for it to begin sending temperature information
  • Install batteries in indoor unit. You should see temperature displayed
Cold weather can cause loss of temperature information
Dec 17, 2016 | Measuring Tools & Sensors
Model WS9611UN-IT - I am unable to receive the outdoor temperature. I have changed the batteries on the outside remote but I still do not receive the outdoor temperature. How can this be corrected
Remove all batteries, both outdoor and indoor. Install batteries in outdoor unit and wait for it to begin sending a temperature signal. Install batteries in indoor unit. You should see outdoor temperature displayed. If not, batteries, transmitter, or indoor unit may be defective.
Nov 16, 2016 | Measuring Tools & Sensors
Why isn't outdoor temperature displayed on indoor unit?
I have a La Crosse unit right in front of me and it is showing +18 F tonight. Saturday, we are supposedly going to sub-zero.
With regard to your problem, La Crosse instructions are very specific about the battery replacement procedure. Remove all batteries from both units, then install new batteries in the outdoor unit. Allow time for the outdoor unit to "initialize" and begin sending temperature data. Install new batteries in the indoor unit and you should see the outdoor temperature displayed.
Feb 12, 2016 | La Crosse Technology Wireless Temperature...
Model c87214. Why does it keep losing outdoor temp signal?
I have had that experience. You may have to repeat initial installation once more before concluding the system is n.g. Remove batteries from the indoor receiver. Review the instructions and verify transmitter was installed in correct location. Do this as you are removing transmitter batteries. For luck, install new batteries in the transmitter. At the receiver, reinstall batteries (or install new batteries). After approx. 10 min., you should see temperature displayed. My LaCrosse system has its wacky days, sometimes displaying no temperature or an abnormally high temperature when morning sun hits the transmitter. Also, successfully resetting is a once-in-a-blue-moon affair.
Dec 28, 2015 | Measuring Tools & Sensors
I have a TX6470 and cannot receive the outside temp on the inside unit
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. If there are reset buttons, also try them.
Oct 16, 2010 | Timex TX6490 Wireless Thermometer with...
Remote sensor does not work after installing new batteries
Oct 15, 2010 | ATOMIC Digital Wall Clock With Temperature
BIOS Digital Wireless Thermometer 312BC SETUP INSTRUCTIONS
I have a BIOS wireless indoor/outdoor thermometer. The indoor base unit doesn't display the outdoor temperature - it is blank - however the other temperatures - humidity, indoor temp, etc., are displayed, What is the problem? We have misplaced the manual so we don't know what to do.
Aug 28, 2010 | Measuring Tools & Sensors
My AcuRite 00992 wireless weather station has suddenly quite displaying the outside humidity and dew point. Batteries are all new. I have lost my manual to troubleshoot this problem.
Aug 27, 2010 | Acu-Rite Adagio Clock Radio
Measuring Tools & Sensors Logo
64 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
