Question about FUJIFILM Cameras
Hi, i need driver for printer fujifilm finepix qs- 70
Posted by deepak on
5 Related Answers
Anonymous
  • 81 Answers
SOURCE: need driver for fuji finepix printer qs-7
use this link to get the driver
http://www.fujifilm.com/support/download/
Posted on Nov 26, 2009
Anonymous
  • 324 Answers
SOURCE: Need driver for fuji finepix printer qs-7 can't
please have a look at this, i am certain this will resolve the issue
http://www.fujifilm.com/support/digital_cameras/software/
regards,
Posted on Apr 30, 2010
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: need driver for Finpix printer QS-70
For drivers look here below
Posted on Jul 25, 2010
rcw1962
Roy
  • 2571 Answers
SOURCE: i have fujifilm printer qs-70
Official support up to Vista only, you could try to run/install under compatability mode
Posted on Jul 31, 2010
Anonymous
SOURCE: Can I use the fujifilm finepix qs-7 photo printer
Hi yes you can but i dont think there is a win 7 driver also you can use your camera direct if its got. pict bribge
Posted on Aug 11, 2010
Cants get fujifilm qs7 printer loaded on windows 7
ry ( FQS07SVR)-your missing driver I use it for windows 7 and it works perfectly for my qs-7 printer I posted a step by step also in same thread some time ago its in SysWOW64 inside the windows file on drive c one other person tried it and couldn't get it to work but mine is fine -good luck heres the afore mentioned guide in case its any use
How to Make the Fuji-QS-7 PHOTO PRINTER Work in Windows 7
Finally reconstructed the steps I took to get QS-7 working perfectly in Windows 7 The following is for dummies like me so bear with it
Step 1 connect up printer as normal leave it switched off
Step 2 on the C drive of your computer access the Windows file
Step 3 from the available items listed select SysWOW64 and open it
Step 4 scroll down to the application name FQS07SVR Right click on it and select the option Run as Administrator (if you hover over it with the mouse it shows exactly what it is- the seemingly missing printer driver for the QS 7
Step 5 when you run /install this al you will see is the window that opens when using command line for about 1 second blink and you miss it
Step 6 switch on your printer and allow Windows 7 to do its thing it will tell you after about 20 seconds that the printer is ready and drivers are installed
Step 7 go to devices and printers it may show you 2 entries for the QS-7 one of which is labelled copy 1 and is strangely greyed out- use this one when selecting print from QS-7 in future -GOOD LUCK! and please let me know if you are successful as this is all I did and now my printer works even though Microsoft's engineers and Fuji say it isn't possible.
Disclaimer -This solution offered only to attempt to alleviate the suffering of those left out in the cold by less than helpful technical experts and unsympathetic companies I can in no way be held responsible for anything that might go wrong
But its worth a go .
Another opinion:
The Fujifilm Finepix Printer QS-7printer is not compatible with Windows 7 as per the Fujifilm's website: http://www.fujifilm.com/products/photo_printer/finepix_printer/#faqs However, if you received the driver disc along with the printer, you can install the vista drivers in compatibility mode.
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Apr 26, 2015 | FUJIFILM Cameras
Lost the cd to install finepix printer qs-7 help
check with fuji s website probably under support for a downloadable driver.
You can also try driverguide.com which is a free driver site and has a large database of drivers
Jun 22, 2011 | Fuji FinePix QS-7 Photo Printer
Lost my cd to install the printer. Need a program to download.
hello!
You can get the Software & Driver from here :
http://www.fujifilm.com/support/digital_cameras/software/#See_All
May 10, 2011 | Fuji FinePix QS-7 Photo Printer
I have lost my installation cd and I cant use my printer through my laptop nor desktop... where can I get those installation?
Hi there, and welcome to fixya,
You need to install the software for you to use the printer via PC here's the link:
Hope this helps,
levibit
Dec 17, 2010 | Fuji FinePix QS-7 Photo Printer
Need driver for fuji finepix printer qs-7 can't work on windows 7
regards,
Apr 30, 2010 | Fuji FinePix QS-7 Photo Printer
How to install QS-70 with Windows 7?
It may or may not work, but try installing as Administrator and setting the program's EXE into "Compatability Mode for XP SP2",and also, running as Administrator. Windows 7 just doesn't want to support any hardware over like a year old... Drivers are a HUGE issue. Especially for older stuff. Compatability Mode is one way round it but not always.
Feb 12, 2010 | Fuji FinePix QS-7 Photo Printer
Cameras Logo
48 people viewed this question
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
