Did you try under the dash board,if not check the glove compartiment,the last place should be under the hood there is one more fuse box.good luck..most comon places are right by the driver side dashboard.
Sometimes when the spark plug cables are dying (or are from a lousy manufacturer) it affects the dashboard. Happened to me when i had a 97 Polo, check that, it could be the same problem.
Consult your Car Owner manual to locate where the Fuse Box is located: Check the appropriate fuse(s) for the appliances in your car that are not working - I suspect that the AirCon, RearWiper and Fog lights are sharing the same fuse as it would be extremely unusual to have 3 separates fuses blown at the same time.
ps. The Polo usually has some spare fuses in/near the Fuse Box.
This is a common occurance in vw's.
In order to turn off the airbag light you need to have a scan tool hooked up to your car because the airbag detected a fault of some sort, or it could be a faulty component in the airbag system itself.
