Question about Mitsubishi Televison & Video
I have a Mitsubishi 65inch DLP tv ive replaced the lamp twice ,black screen i can hear it power on and fan running status light stays red and lamp blinks green to no end,black screen and no sound ??
Posted by Chris Zamplione on
  • Mitsubishi Master
  • 18,438 Answers
This might be the lamp ballast that is out. Parts for those units are hard to get because they are obsolete.
Posted on Apr 24, 2020
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
Anonymous
SOURCE: Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Posted on Mar 23, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Mitsubishi XD510U Status light is blinking
Page 30: replace the lamp (Page 25)
Spare lamp for XD510U/XD510U-G/SD510U: VLT-XD510LP
http://www.retrevo.com/support/Mitsubishi-XD510U-Projectors-manual/id/15978dj994/t/2/
Posted on Jan 23, 2011
Black screen
Sounds like you need to replace the lamp. An original Mitsubishi lamp will last 7 to 10000 hours. It's a no brainer to replace. Buy the lamp from Mitsubishi or a dealer. Do not buy one over the internet. Those are awful...
Dec 31, 2013 | Mitsubishi Televison & Video
I have a mitsubishi 735 series dlp tv. Has red blinking status light. The error code was 4 blinks then two blinks. Do you know what is wrong with it?
That's the error indicating the lamp/ ballast fan has stopped working. You can get the Mitsubishi lamp / Ballast fan 299P321010 used in the V39 series DLP televisions. It comes with installation instructions and is available from www.tvrepairworld.com under the Mitsubishi DLP parts category.
Aug 25, 2011 | Mitsubishi Televison & Video
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
My 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Feb 20, 2011 | Mitsubishi Televison & Video
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
