Question about Measuring Tools & Sensors
Can I pair a 915mhz thermo sensor transmitter with a 433mhz weather receiver? Is there a workaround? Can i change some internal components?
If there is no workaround please let me know
Posted by Pierce Burgardt on
ray gallant
    Top Expert:
  • Measuring To... Master
  • 68,557 Answers
No they only work with same frequencies . no work around either
Posted on Apr 22, 2020
Testimonial: "okay thank you"
5 Related Answers
Anonymous
  • 515 Answers
SOURCE: Hands free calling and FM transmitter
Old post, but here we go.
1: Update to latest firmware from tomtom, for Gox20/x30 that is 8.351
2: Make an silent mp3 file and put that onto device
3: Play silent mp3 in loop
4: Send nav instructions over fm to radio... et voila!
Posted on May 27, 2009
Anonymous
SOURCE: I have a weather station
Check Out the following
http://www.westclox.co.uk/instructions/Gifts%20and%20Gadgets/Science%20Museum/SM2282%20-%20RC%20Weather%20Station%20Wall%20Clock%20Pg%202.pdf
Posted on Dec 23, 2009
Anonymous
SOURCE: Hampton bay ceiling fan with built-in remote receiver
In case someone else stumbles upon this:
I replaced the remote receiver on one of these fans. jb is right just the top housing that touches the ceiling needs to be removed. Twist it counter clockwise and pull down. You'll see all the wires and the remote receiver. It might not seem like much room to work with, but you can remove the wires and slide the receiver out sideways to replace it or if you can't see the dip switches. Too bad Home Depot is too cheap to even provide instructions when they send you the replacement remove receiver.
Posted on Jan 24, 2010
Anonymous
SOURCE: Sio/Scan Temperature Transmitter 433MHz for batteries
I just changed the batteries yesterday. It was hard to open the battery compartment with bare hands/finders. I used flat screw driver to poke into the notch in the center of the transmitter. Or you can try poke into any **** around the compartment. It works!
Posted on Apr 24, 2010
Jeff
SOURCE: how do i set the
If you've lost the signal, press and HOLD the search button until you hear a beep. Then the number of the channel being searched will start flashing. It takes about a minute or two and then will read out the temperature.
Posted on Nov 12, 2011
BIOS weather 315BC-TX I see a little switch [3 2 1] which situated under a batteries cover of an outdoor transmitter. What the switch for?
I'll admit I don't know the answer, but I can see that the receiver can receive up to three transmitters - so an educated guess would be that each transmitter can be identified using this switch??
Oct 02, 2017 | Measuring Tools & Sensors
I have no transmitter signal from my wwc model ws1600IT 915mhz TX22IT even after changing Batteries in accordance with instruction of setup, tried this several time, this unit previously worked ok.
Be sure to remove all batteries at both ends then reinstall/install batteries at transmitter end, wait for it to initialize and begin sending data then reinstall/install batteries at the receiving end. You should see temperature displayed.
Oct 25, 2016 | Measuring Tools & Sensors
When daylight savings time started the clock did not reset itself completly. the hour is wrong,
You need to set it to automatic daylight savings time in settings, mine did the same
Apr 20, 2015 | La Crosse Technology TX37UIT 915MHz...
Will not display outside temperature even though I changed the battery on both the inside and outside unit
Find reset pin hole on base unit. Push in with a paper clip. Pin hole may be in battery compartment.
Mar 13, 2015 | La Crosse Technology TX37U-IT 915MHz...
There is no signal from the outside sensor for wind, temperature etc. New batteries made no difference.
I had the same issue. I ended up actually cutting the enclosure off to look inside. (I figured "It's not working anyway, what do I have to lose.") A good number of the conductors on the printed circuit board were corroded to the point that they were gone. Some components were literally falling off the board.
I am pretty good with a soldering iron but after looking at the damage, I threw the transmitter away.
Nov 18, 2013 | Lacrosse La Crosse TX31U-IT 915MHz Outdoor...
Indoor unit and outdoor unit not connecting
If the outdoor transmitter and indoor receiver communicated for a time and now don't, it could be time for a battery change. The usual procedure is to change transmitter batteries first, then the receiver. You have to wait for something like 10 minutes for the units to begin to "talk". All of this should be covered in the instructions you received with your system
Oct 14, 2013 | NG Weather NATIONAL GEOGRAPHIC 265NC
Taylor 433MHZ cable free thermometer won't show outdoor temp
Check battery in outdoor sender and reset main unit to receive transmission of data. If nada could be that you have an issue either with the sending unit or the receiving unit of your weather station. Has happened to me a few times already so .................
Jan 22, 2013 | Measuring Tools & Sensors
How do i set the thermo sensor 433mhz to my westclox 70034 model
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Oct 11, 2010 | Vacuums
Thermo clock RAR312 not picking up outdoor transmitter temperature. Replaced battery but still nothing.
take a paper clip and reset the reset button located in the battery compartment. Then, try each of the 3 channels until you get a reading in the outside temp field. Wait a good couple of minutes at each channel setting before determining the units are not pairing. Do this with the units side by side for signal acquisition, then once acquired, move the remote sensor outdoors. Hope this helps!
Sep 24, 2010 | Office Equipment & Supplies
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
Measuring Tools & Sensors Logo
67 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
