Question about Tablets & eReaders
How can I update de android of the tablet eviant model no. ev10qc16
Posted by Luis Manuel Casas on
Vernon Taylor
  • 7,446 Answers
Each version of android has a fairly limited life.
Each hardware manufacturer has to fiddle with the android software to make it fit their devices, consequently updates don't come from google but have to come from the device manufacturer.
If it is possible to update the android operating system the device menu will list the option though many low cost generic devices aren't updatable (unless you are a computer scientist).
If updates are available it is usually for a limited time, often until a new version of android is released. Some apps also have to be updated but they do reach a point where they no longer function with earlier versions of android...
Posted on Apr 22, 2020
Could you give me customer service number please for eviant tablet manufacturer thanks
EVIANT CUSTOMER SERVICE:
Technical Support
1-866-935-4396
LINK:
http://www.eviant.com/frontend1/contact.asp
There is also a physical address on that page and more contact info.
good luck
Tablet keeps going to factory reset when I turn it on, how do I stop it
It must have a corrupted file when loading, I suggest you reload the operating system and start with a clean slate.
How do I get the language on the eviant tablet back to English?
Not sure about Evant, but my daughters Android had the same problem
Start > Settings > Language 'A' > English is usually the first on the list
How do I get my Eviant Android Tablet to turn on? I have had it for over a year and it was charging. I checked and it showed it was fully charged, but it will not turn on.
This is most likely your battery that needs to be replaced. A bad battery will show fully charged and not have enough juice to start the device up.
My tablet will not connect to WiFi. Problem just started a day ago.
Have you made any changes to router? If no, disconnect it, turn off tablet keep them for a minute then turn back on. If that doesn't help I'd suggest to factory reset tablet.
I CAN NOT GET MY TABLET TO OPEN UP TO APP SCREEN, EVIANT IS THE ONLY WORD THAT WILL SHOW. HELP, HELP
You can try a hard reset.
You do not state what model but generally.
If its an Android OS you will need to try holding the power on + volume +up +down Or power on+home +volume down then Factory reset.
You will lose of your personal data.
2answers
How do I transfer photos from eviant tablet to HP PC? The tablet plugs into the wall with no way to insert an end into my PC. The only way I've been able to transfer is thru email a few at a time.
The USER guide here http://www.qvc.com/Eviant-8-Tablet-w-8GB-Memory-Android-4.0-&-Google-Play.product.E223749.html
(Click on second set of red words below pictures to download. marked user guide in red.)
Shows you how to transfer files (photos) to your PC using a micro-usb to usb cable from your tablet to your PC.
4helpful
How to reset password for eviant tablet?
Generally speaking, if you have set a password on a device and have forgotten it, you will need to wipe/format the device to factory specifications. That means just like when you bought it.
3 RESET WAYS on ANDROID TABLETS REVIEW
2helpful
I turned the talkback feature on and now im locked out of my tablet and i can't type in my pin code
Just make a factory data reset.
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
Tablet is less than a month old and has significant battery charge, and in the middle of playing an everyday app game the tablet went into a white noise picture. I shut it off by holding the power button...
hold down power and volume up and down at the same time for 10 seconds and then release. should reboot. if not then there is something wrong with the board or a software glitch.
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
