Question about Maytag Refrigerators
I have a maytag model MZD65GE The water on ice maker just keeps runniing. What can i go to fix this
Posted by Leighton Wiley on
5 Related Answers
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Maytag ice maker wont fill upwith water
is the icemaker cycling at all? pull the front cover offf of the icemaker and verify that the gear isnt broken. if so replace the motor module. if thats ok the next 2 things could be either a frozen fill tube or bad fill valve..
Posted on Dec 12, 2007
arikrom
911 SERVICE TODAY
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Posted on Dec 30, 2009
Anonymous
  • 16 Answers
SOURCE: Ice maker not making ice
check the water solenoid for the ice maker on the back
Posted on Jun 11, 2010
Rahman Rufai
  • 532 Answers
SOURCE: Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Posted on Jul 12, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my maytag refrigerator sidebyside ice maker stop working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnc
Posted on Sep 30, 2010
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
Maytag MFI2266AEB black refrigerator
Check there's water coming through and circulating
Apr 25, 2012 | Maytag Refrigerators
Maytag model MZD2766GEW. The water tube supplying
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jun 28, 2011 | Maytag MZD2667HE Side by Side Refrigerator
Ice maker will not make ice,have water but no ice.
Many people see this as a problem but if you take a look you have two separate controls for the ice and water system. So what's next? Look for a model number around the fresh food section door and sometimes your model number you may have looked at it every time you open the door and did not realize that is what that is. Locating Your Model Number or lets go to Maytag=> HERE and in the pull down choose if your model is a side by side or other than a side by side. Neat Tool! So now back to your ice maker and being the way most ice makers are they have a side to the water valve on their own somewhere near the water control valve on back of your refrigerator and near floor on most. The ice maker in most cases tells that water valve when the ice maker needs water again so many times it is the problem anyway. If your ice maker has cubes in it and still will not drop the cubes then it is the possibly the ice maker causing the problem but if you fill the ice maker with tap water and it freezes and then dumps cubes into the ice bin then the problem is the water control valve on the back of your refrigerator. Here is a short clip below. And here is a search for=> Maytag Refrigerator Water Control Valves and a search for=> Maytag Refrigerator Ice Makers I hope this has helped, Thanks, Sea Breeze
Here is how to=> Replacing The Water Valve on my Refrigerator
Apr 19, 2011 | Maytag Refrigerators
Ice maker not working. water supply goood. makes loud noise on and off . Maytag Ref. model MZD2665HEB
heatman101
gf342
Jul 19, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
No water going to the ice maker
You could have either the ice maker causing this or the side of the water control valve that feeds the ice maker is defective. Here is a simple test to see which is causing the problem. Fill ice maker with tap water. If after the water freezes the cubes drop into the ice bin then the water does not refill it will need the dual water control valve replaced. If ice just sits there then the ice maker needs to be fixed or replaced depending on your Maytags model number. Let me know the model number and results, Thanks, Sea Breeze
Mar 18, 2010 | Maytag Refrigerators
How do I decrease the water level in my Maytag Ice Maker
depends on the model of ice maker not your refer,,
if you have a white box on the end see if you can pop it oiff
if you have the adjustable model you will see a screw with a plus minus
turn to adjust.... make sure you unplug the unit first
1/4 turn is 1 oz
Oct 24, 2009 | Maytag - Model IC11B
My maytag refrigerator will not drop ice cubes or crushed ice or water
OK, The most likely reason is the water control valve is defective for the ice maker or the ice maker thermostat is not working and will not tell the control valve to open for water. If ice is just sitting in the ice maker and it will not cycle then I believe the ice maker may be the problem. Now if you could tell me the model number of your Maytag I can send you a manual and tell you the part numbers. Try this, if the ice maker is empty and turned on fill with tap water and allow to freeze. If the water freezes and then dumps I will know that the water valve is not working. If the water just freezes and sits there then again it is the ice maker. Problem is I'm not sure if yours is the mechanical ice maker or has a control board in the front. They just made too may different models. Let me know and I will check back and if you find the model number the service manual I will upload to you.
Sep 07, 2009 | Maytag Refrigerators
Water wont fill ice maker
the relay is the ice maker , buy the kit that contains the valve and it is a complete new ice maker system.
easy to find at sears parts.
Phil
Jun 11, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
74 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
