Question about HP Office Equipment & Supplies
HP Photosmart C6283 Ink System has Failed Error:0xc18a0306 Can't clear this error
Posted by galiver joon on
Attique-ur-Rehman
    Top Expert:
  • HP Master
  • 2,677 Answers
3 Related Answers
Anonymous
SOURCE: HP Photosmart C5180 Ink System has Failed Error:0xc18a0306
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
Posted on Nov 29, 2008
Michel Smith
  • 1218 Answers
Here is what you can try:
1. Turn off the power and unplug it from power source.
2. Open the right side of the printer (looking at the front).
3. Disconnect, by pulling gently, both white flat ribbon cables off the main circuit board.
4. Plug in the power source and turn the printer on. Wait till you get a error message and push "OK".
5. Unplug the power source.
6. Reconnect the flat ribbon cables by aligning and carefully pushing them into the conectors on the main circuit board.
7. Plug in the power source and turn the printer on (Printer preparing occurred).
8. The 0xc18a0306 error should now be gone.
get more information for HP printer errors . Hope this helps you.
Good Luck!
Posted on Sep 03, 2010
silawrence
Silas Lawrence
  • 906 Answers
SOURCE: HP Photosmart D7360 ink system has failed. How do I fix this?
with 2 new cartridges installed, shut the machine off and back on again.
Posted on Jan 07, 2015
Jan 06, 2015 | HP Photosmart D7360 Digital Photo Inkjet...
How do i fix ink system has failed error code on my hp photosmart c5180 printer?
try master rest for hp C 5180
Master Reset:
Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. . This sorted it.
Jul 26, 2014 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
A Google search found this possible solution for you at HP:
Ink System Failure C6180 error 0xc18a0306
Jul 25, 2014 | HP Photosmart C6180 All-in-One Printer,...
I am having problems with my PS D7360. Error code 0xc18a0306 keeps coming up. I have tried the pineworks suggestion but it did not work. The printer has been sitting for a while.
Found this here it's worth a shot. http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Ink-System-Failure-C6180-error-0xc18a0306/td-p/161866
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
May 28, 2011 | HP Photosmart D7360 All-In-One InkJet...
My HP Photosmart C7283 All-in-One printer has an error message: 0xc18a0306. Ink System Failure?
My HP Photosmart C7283 All-in-One printer has an error message: 0xc18a0105. Ink System Failure?
May 04, 2011 | HP PhotoSmart 1215 InkJet Printer
Error message says: ink system has failed. Unable to print. refer to printer documentation. Error: 0xc18a0306. Turn power off then on again.
Hi
Please see this link to solve your issue--
HP Printer ink system Failure
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | HP Photosmart C6280 Printer
Oct 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
61 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
