SOURCE: canon ir3300 is giving me error code E6002-0003, h...
Turn off the copier using the power switch on the right. Turn it on again holding 1 and 9. You should see rectangles on the screen. Once this is finished the copier should be in download mode (If this process hangs or doesn't get started the disk will need to be replaced by a tech). Once you reach download mode you'll need a tech to flash the hard disk to get the copier going again. If this doesn't work, the hard disk will need to be replaced. In any case your hard disk is dying and will need to be replaced soon.
SOURCE: i want canon ir3300 multifunction printer drivers for windows xp
i want ir3300 cmputer drivers
SOURCE: need a hard disk recovery software for canon ir3300
hi i am form India i have canon ir 3300 i am getting error for E602-003 pls no technician
