Question about Samsung Televison & Video
My samsung Smart TV, it is showing the Samsung logo without pressing any key in remote control. And The logo Disappear for seconds and then Appear Again, It stocks on that loop.
Posted by fredi on
David Spradling
    Top Expert:
  • Samsung Master
  • 11,272 Answers
Check input or source if ok or not able to change bad board return tv
Posted on May 23, 2020
5 Related Answers
Anonymous
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
Anonymous
  • 96 Answers
SOURCE: Toshiba 2100TB tuning without the remote control
If you are sure, that there's no way to do it manually on the TV, there are only two solutions: buy a new remote control according to your TV set model (sometimes it's hard to find) or buy a universal remote control
Posted on Jan 30, 2009
Anonymous
  • 4 Answers
SOURCE: Samsung TV remote control controls two Samsung TV in same room.
You cannot reprogram the samsung remotes. I just installed three samsung tv's on the same wall. I used a harmony 900 remote. It has a rf receiver with an IR blaster two IR emitters. You can designate each emitter to a specific device in the remote. I used the main remote IR for the main tv, The blaster for the a/v receiver,blue ray, ect. Then I used each of the emitters for a tv. I can control each of the tv's independently with no interference.
Posted on Oct 27, 2009
Anonymous
SOURCE: virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
Posted on Mar 30, 2010
nanbane
  • 5 Answers
SOURCE: SAMSUNG WAVE 525 BADA LOGO LOOPING
For this problem contact the mobile service provider......
Posted on Oct 22, 2011
I just bought Samsung UHD TV SERIES7 no where manual shows how to set sleep timer
The sleep timer is accessed through the Menu under System > Time. You may need to set the TV time first which is in the same sub-menu area. For the sleep timer using the smart control, press Menu/123. Use the pointer button to steer to Menu then press the Pointer. Repeat this to select System. Select Time. Then select Sleep Timer and choose your time (up to three hours) when you want the TV to turn off. From the regular remote, press Menu. Use the arrow keys and press OK to move through the above menu steps. You can also do this from the Menu button on the Control Stick (joystick type control) on the back of the TV (lower left-hand side).
See page 126 (page 132 of the PDF) of the e-manual for the JU7000 series TVs for additional information or the section on setting the TV time. The e-manual is available online or through the TV. To read this manual, press the e-manual button on the regular remote. If you have the smart control, press Menu/123. Then select the e-manual from the on-screen remote. Alternatively, press Menu and then select Support > e-manual. The quick guide does not have the information on setting the timer. See https://www.samsung.com/uk/support/model/UE40JU7000TXXU/ under the Download Manual section. You may need to expand the list.
I hope this helps.
Jun 15, 2018 | Samsung Televison & Video
Bought a used Samsung smart tv. Netflix still has precious owners account attached to Netflix. How do I remove it.
  1. Samsung Smart TVs ' Technology To Change Your Life ' samsung.com‎
    Adwww.samsung.com/UK/SmartTV‎ Quick & Easy To Use, The New Generation Of Samsung TVs Is Our Smartest Yet.
    Types: Quantum Dot Display, SUHD Nano Crystal TVs, UHD Nano Crystal TVs, UHD TVs, HD TVs
    Edinburgh · 1 retailer nearby
Search Results Remote Control Method
  1. Press the "Up" arrow key twice on your TV's remote control while in the Netflix app.
  2. Press the "Down" arrow key twice.
  3. Press the "Left" arrow and then the "Right" arrow. ...
  4. Press the "Up" arrow four times. ...
  5. Press the arrow keys to navigate to the "Deactivate" option, and then press the "Select" button.
How to Log Off of Netflix on a Samsung TV ' It Still Works ' Giving Old ...
https://itstillworks.com/log-off-netflix-samsung-tv-23508.html
Feb 04, 2018 | Samsung LN32A330 32 in. LCD TV
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Led tv
is this on all source/input selections?
Apr 22, 2014 | Samsung BN94-05429D Main Board...
How to use the samsung BN59-011348 remote control
You have to pair the querty side of the remote. Go up to your samsung smart TV 8 inches or less to pair. Press SYM and TAB at the same time. You should notice on the screen that it states "Pairing." Your TV should confirm. The keyboard will load up when you press a key. Follow information on TV screen. Some applications like Netflix do not work with the remote. You can use your query side when you press on an app. If a screen pops up like for web browsing just type like a keyboard.
Feb 19, 2013 | Samsung BN59-01134B Remote Control...
Samsung dvd-85k unlock code
Samsung DVD-V8500K
1. The player should be powered on, the tray closed without any disc inside, the logo "DVD Video Samsung" visble on screen and the message No Disc must have already appeared.
2. Press the "Subtitle" key on the remote - "No Disc" should disappear.
3. Using the remote control, key in the code
"5, 3, 8, 1, 4"
4. A number should appear - this is the player's region number that was last programmed.
5. Press the number of the region you require, or 9 for region-free.
6. Press the "Subtitle" key on the remote - region number should disappear.
7. Press Standby on the remote control.
NOTE:
Origin of this player is Region 5 so it`s a default setting
If code "5, 3, 8, 1, 4" doesnt work try this codes:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
please rate me. its most helpful
Nov 07, 2009 | Samsung DVD-V85K DVD Player / VCR Combo
Samsung HP-T4264 will not autoprogram, locks up on deleting scrambled channels
Reset to factory specifications by turning tv on, and then using the remote, hit power off, mute key, 1, 8, 2, and power on. Interval between key strokes is less than 3 seconds. When tv comes back on it shows Service Mode Display, key up to reset and press enter. Was able to autoprogram without any problems.
Oct 14, 2009 | Samsung HP-T4264 42 in. Plasma HDTV
To change my samsung dvd 1080p7 to multi zone
The following hack was meant for a Samsung HD870 that shares many components with the HD1080P7 (Region 2 restricted).
It would have to be done using the original remote control that came with the DVD..
1. Turn on the Player with no disc on the tray, displayon TV would be "No Disk";
2. Press the "Repeat" key on the Samsung remote control;
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 would appear on the screen for a short time;
4. Press "9". Number 9 is displayed on the screen;
5. Press the "Open/close" button on the remote. The tray will open. Leave it open for a few seconds; and
6. Press the "On/off" button in the remote.
This hack was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 06, 2008 | Televison & Video
How to change a Samsung DVD HD850 player from Region 1 to multi region?
1. Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
3. Press the keys: "5 7 5 3 8" on the remote. A number must appear n the screen. That is your player's current region.
4. Prss the number for the region you want to use next ( 1 , 2 , etc). If you want your dvd player to be unlocked for all the regions press "9". A number should appear in the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
Apr 24, 2008 | Televison & Video
SANYO DS32920
Did the black box disappear or disappear and then re-appear?
If yes> TV station is broadcasting a caption text signal without any textual data. > Press the RESET key twice.(Customized settings will be reset to factory defaults).
To retain customized settings just turn captioning OFF.
1. Press the CAPTION key on the remote control.
2. Use the 0 key to select OFF, cap1,cap2,Text1,Text2,or Quickcap.
Feb 05, 2008 | Televison & Video
Televison & Video Logo
35 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
