Ovens Logo
Question about Belling Ovens
Our belling double oven lets lots of steam and heat out with the door closed, and when it gets hot it cuts out. The grill also cuts out after 10 minutes. Any ideas please
Posted by Richard Hobbs on
Attique-ur-Rehman
    Top Expert:
  • Belling Master
  • 2,677 Answers
One of the prime causes of your electric oven cutting out is the thermostat, this is a safety procedure that will protect your oven from getting too hot. ... The only real way to solve this problem is to replace the thermostat to ensure your oven doesn't heat up too much.
https://www.repairaid.co.uk/oven-repairs/my-electric-oven-cuts/
Posted on Apr 20, 2020
  • Attique-ur-Rehman
    Attique-ur-Rehman Apr 20, 2020
    Whilst the thermostat may be the cause of the oven overheating, inadequate ventilation may also be the cause. Consequently, if there is inadequate ventilation to the oven, the oven may overheat and cut out. A specialist oven technician will be able to assess your appliance and ensure appropriate ventilation is present.http://www.cookersolutions.com/news/late...
Belling oven wont heat on any setting
Check if the timer is set? If that is okay, a failed element is the most likely cause. Disconnect the leads and check continuity with a test meter.
Belling Oven is Not Heating Up You can test whether your Belling oven is heating up correctly by turning the oven on, setting the temperature and letting it sit for five minutes. If the oven cavity is not hot when you open the door, it is likely that your oven element is broken.
Belling Oven Not Working? Here's How To Fix it
Kebs208dss11 model double oven. When upper oven is on with door closed, steam can be seen escaping from top of door. Door is closed all the way. Even when putting pressure on door to make sure it is...
The first thing I'd suspect is a poorly fitting door seal / gasket. This will permit the heat inside the oven to escape. Check to be sure the the one installed is defective (cut, split, frayed, dislodged, etc.) Replacement parts:
http://www.appliancepartspros.com/whirlpool-gasket-door-w10074200-ap3892420.html
Make sure this is the part you need before ordering.
2helpful
During cooking the oven goes off. There is often a lot of water/steam present. Sometimes after a while it comes back on?
It could be that the overheat thermostat is kicking in, albeit earlier than it should do. Have you checked to see that the oven thermostat is working correctly and is not heating the oven up too much ( does the neon go off and on) and is the oven cooling fan running ok in the background. If these two appear to be ok, then you may need to replace the overheat thermostat.
(The oven cooling fan should remain on for about 5 to 10 mins after either oven or grill has been used. If this isn't happening or it is not running correctly then that is why the overheat device is shutting the oven off). As a thought, are the top oven and grill working ok? if they are, then it narrows it down to either the oven thermostat or the overheat sensor.
5helpful
2answers
Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
My grill on my oven is melting the knobs and the heat is that hot i have to stand away from the cooker i have to switch the knobs off a tea towel and it fills the kitchen with smoke is this covered under...
I assume that you are grilling with the oven door open and not closed, if you are grilling with the door closed, then this will cause an overheating problem,if this is not the case, then I would suggest that the grill regulator is faulty,. and needs replacing.
It not covered by health and safety rules.
Please leave any comments you may have, as I like to know if my comments are appropiate.
Thanks.
My hotpoint ew61 double oven doesnt come up to
If it is heating, but not getting hot enough, then it is possible the thermostat is cutting the element off too soon, in this event, you will need to replace the thermostat.
If it is not heating at all , then the element is probably faulty.
Thanks.
Nov 14, 2009 • Ovens
1helpful
My stoves 720ef oven goes off if it turned up over 140 deg c also the grill in the top oven does not get red hot
Is the cooling fan running in the oven? Does it also continue to run when the oven controls are turned off to let the oven cool down?
There are ventilation grills below each door on the oven. You can see these when the doors are fully open, just look under each door to see if they are clear and not blocked up.
15helpful
3answers
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
