Question about Blaupunkt Televison & Video
Hi I have a blaupunkt sty 39" tv when I switch on the tv the sound comes clear but I see a black screen with faint pictures
Posted by Kuda on
    Top Expert:
  • Blaupunkt Master
  • 76,416 Answers
What type of TV is yours? LCD or CRT type? If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/.
Posted on Apr 19, 2020
My blaupunkt lcd tv goes on but no picture very faintI have sound
Did it ever work right? How old is it? under warranty?
If the pic is very faint, I suspect the background lamps are burned out.
If the sound is very faint, possibly a power supply problem.
Please click the Comment link to respond.
Mar 17, 2018 | Blaupunkt Computers & Internet
Sound but no image on Hitachi 42pd5000
Two things need to be checked. The ballast board and the T-con board. Shine a flashlight on the screen with the TV on...If you see a faint picture moving, then the T-Con board is OK. The ballast board for the white backlight is bad. If you don't see a faint picture, then the T-con board is bad. You can get parts here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
May 23, 2017 | Hitachi Televison & Video
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
How can I fix black screen on Philips 42" LCD TV?
chances are it is cracked solder joint on internal board,
check link below, press the helpful button
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Jan 24, 2016 | Philips 42PFL7422D 42 in. LCD TV
RCA L32HD32D no picture
Most likely you have a bad back lamp. Most times when this occurs, the screen will come on for a second or two then go off. Replacing a back lamp isn't a job for do it your selfers. It will involve completely disassembly of the LCD panel.
Jan 12, 2013 | RCA L32HD32D 32 in. LCD HDTV
My LTV-32w6 westinghouse powers on & has sound but displays black screen with very faint colored vertical lines. It shows like this for about 1min before it goes into standby mode & the blue power...
Depends on what is causing it...
Vertical bands of faint black are generally caused by filtering capacitors and can be found in the power supply or the 5 volt supply or even the Video processing circuit...it is not an easy task to identify the source of Video hum bars.....we also call them Jailbars.
Another problem seen is faint black lines caused by the TV set being in 4:3 mode all the time....right at the edge of where the picture ends and the black pillars begin, we see a faint black line that never goes away and is normally seen with a full screen....
That is actually image retention, but it's caused by the crystals that create the picture becoming polarized or ionized over a very long period of time....and it's not easy to DE-Polarize them !
But there are some theories out on how to do that....
Certain people suggest running the TV overnight with an ALL-WHITE picture and some suggest an ALL BLACK PICTURE...and some suggest alternating between both !!
Now, a black picture is easy to make, you just deactivate the Video Mute (blue screen) and set it to an unused Video INPUT overnight....
About the only way to make a white screen is to use the USB port for pictures and take a very bright outdoor shot of a piece of white paper that hopefully is out of focus too....That would create an all-white picture that you can plug into your TV set overnight....
Now if you decide to try this, deactivate any displays on your TV set...all you do is press the display button until the Video and/or USB input numbers disappear....
Next day , set it back to normal TV and see if it's gone or if it's REDUCED....try it again if needed, or try the exact opposite if you see NO RESULTS....
Sep 20, 2012 | Westinghouse Televison & Video
Plasma screen suddenly went out
its a lcd ? replace the lcd lamps or the inverter
May 04, 2012 | Panasonic Televison & Video
Have sound but no vision?
When the screen goes black, shine a flashlight on the screen to see if you can see a faint picture. If you can then the ballast board for the backlight is bad. If you can't see a faint picture, then the T-CON board needs replacing. You can get parts from here:
Jan 12, 2018 | Philips 32PF9830 32 in. HD-Ready LCD...
Had a major electric surge and now tv has no picture, but has power to it?
when on black screen, put a flashlight onto screen, if u can see picture, its the capacitors (2), 3.00 in parts, follow the power cord to the board inside, look for capacitors that are bubbled on top,
Dec 21, 2011 | Samsung Televison & Video
No picture,no sound,blank
This set is very popular for the capacitors to dry upa and go bad in the main SMPS as well as the switching power supply. If you have no know how on how to test capacitors or solid state electronics please take the set into a repair shop for an estimate
Jul 28, 2006 | Sanyo AVM-3659S 36" TV
Televison & Video Logo
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
