Question about Pioneer Car Audio & Video
SOURCE: Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Posted on Nov 04, 2006
SOURCE: Pioneer GM-7200M power problem
Check your GROUND wire might be touching something and making bad contact.
Posted on Jun 10, 2009
SOURCE: Pioneer GM-7200M 800 Watts Mono Amplifier
you Amp is overloading and going into protection mode. if it cuts out with the wire u were using first then their would be no need to upgrade the size of ur wire cause that would only be, doubling or trippling the power u are getting threw those wire now. bottom line the 2 subs u are using are obviously to much for the amp. try dropping the OHM's by connection the subs together and runnig just a single positive and negative to the amp! or just get a better amp
SOURCE: I need a schematic for the pioneer gm-62 mini car
here is a link
http://akamaipix.crutchfield.com/Manuals/130/130GM6200F.PDF
Posted on Jun 29, 2009
SOURCE: Pioneer GM-7200M 800 Watt Amp shut off and wont turn back on.....
Hiya, first check by triggering or powering the amp manually by putting a voltage at the trigger. Just use a jumper from power. If the amp comes on then check the feed from head unit. Loose wire, inline fuse near the head etc.
If it still doesn't come on the hate to say its gonna have to go in for repair. Could be anything inside from protection, blown track etc.
Hope that helps
Posted on Jul 27, 2009
Dec 30, 2009 | Pioneer GM-7200M Car Audio Amplifier
Jul 27, 2009 | Pioneer GM-7200M Car Audio Amplifier
Jun 09, 2009 | Pioneer GM-7200M Car Audio Amplifier
Jun 05, 2009 | Pioneer GM-7200M Car Audio Amplifier
Mar 19, 2008 | Pioneer GM-7200M Car Audio Amplifier
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Oct 30, 2007 | Pioneer GM-7200M Car Audio Amplifier
Oct 29, 2007 | Pioneer GM-7200M Car Audio Amplifier
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
70 people viewed this question
