Question about Maytag Refrigerators
I can't seem to figure out how to remove the glass from the plastic housing of a Maytag refrigerator model M1TXEGMYS01
I'm not sure if all my details came through... I can't see them... it also seems that I can't post pics with my question so please see the only "answer" I've given because it's actually my question... apparently in the wrong place. thanks for your time!
Posted by Jeremy Wheeler on
john h
    Top Expert:
  • Maytag Master
  • 23,504 Answers
Some shelves glass lift out the others dont
Posted on Apr 18, 2020
Testimonial: "Thanks for the confirmation. As baffling as it is to not be able to remove the glass for better cleaning... I suspected this to be the case."
kg to lbs
Such a nice website and very help full. Kg to lbs converter is a very smart and convenient system of formulas that is able to convert any value of kilograms to pounds and another way around. The basic idea of such a solution is to make people's life easier and do not bother them with hard calculations. .here is a link of my website and you convert <a rel='nofollow' href="https://howkgtolbs.com/"> Kilograms to pounds </a>
Posted on Apr 24, 2020
5 Related Answers
SolutionGuy
Tracy Farrell
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
Anonymous
  • 384 Answers
SOURCE: switch on Maytag refrigerator broke. I have a
No. Order a replacement from Maytag.
Posted on Jul 07, 2009
Anonymous
SOURCE: Sanyo counterhigh refrigerator model SR-4911.
remove shelves and insert keg.
Posted on Feb 03, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
  • 102366 Answers
SOURCE: In late December I bought a house with a Maytag
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%2012828140.pdf
Posted on Apr 28, 2011
I cannot remove light bulb Maytag model mtb2156de refrigerator
Unplug unit heat plastic light socket with blow dryer and use leather gloves. If the glass breaks bend in the broken light bulb socket with needle nose pliers and turn out.
Oct 30, 2013 | Maytag Refrigerators
How do you remove the plastic control housing so I can replace the defrost timer on a Maytag MB1895AE refrigerator. Freezer is on top. Thanks!
In the front of that housing between the dials is a 1/4 inch hex headed screw and also one about 6 inches back from that one is a second one. remove those screws and the control panel will come down.
GENE
Aug 27, 2011 | Maytag MTB1895AE Top Freezer Refrigerator
How do I change the water filter
Removing and replacing a water filter - upper right hand corner location
Filters situated in the upper right hand corner of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
  • Finally, reset the 'change filter' indicator light, if your refrigerator has one, at the front of your refrigerator. The procedure for resetting the change filter indicator light can vary from fridge to fridge. Typically, the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
Removing and replacing a water filter - center ceiling location
Filters situated in the center ceiling of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • Turn the filter a quarter turn to the left, in a counter-clockwise motion. The 'unlocked' symbol on the filter will be lined up with the indicator line that is molded into the refrigerator just above the filter. Allow the ears of the cartridge to disengage from the filter holder.
  • Gently pull down on the filter, being careful to not spill any water still in the filter. Discard the used filter.
  • Remove the new filter from its packaging. Remove and discard the red plastic cap found on the top of the new filter.
  • Apply the appropriate month sticker to the filter to remind your self to remove and replace the filter in six months' time.
  • Insert the new filter into the filter opening. Line the 'unlock' symbol on the filter up with the indicator line that is molded into the refrigerator above the filter. Turn the filter a quarter turn to the right, in a clockwise motion. You will be able to feel the filter stop when it is all the way in, and the 'locked' symbol on the filter will now be lined up with the indicator line above the filter.
  • Close the refrigerator door and dispense several glasses of water through the water dispenser in the door in order to purge the new filter of any impurities. Open the refrigerator door again and check for leaks. If you find a leak, remove and replace the new filter again.
Nov 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Ice & water dispenser get stuck, water & is keep coming out os dispenser even after you remove glass
Unplug unit
Remover dispensor housing. Careful not to break tabs.
You will see the white plastic actuator arm.
Follow the arm to where it becomes part of the main support.
Push the arm you will see where the main support is catching on a plastic *** on the rear housing.
Cut or file off part of the ***. so it wont catch.
Reassemble dispensor.
Jan 18, 2010 | LG LSC26905TT Side by Side Refrigerator
Maytag refrigerators mtbe1956de liquids have dripped on to the bottom glass shelf and seeped under the edges where it cannot be cleaned. do I have to remove the vegetable drawers and totally dismantle the...
brute force on the glass shelf.... it was just stuck in place by the cold sticky liquid that had seeped under the edges and bonded the glass and plastic together
Jan 12, 2010 | Refrigerators
I cannot figure out how to adjust my shelves. There is a blue tab at the back and I cannot seem to pry it loose or remove it ino order to move the shelves.
thast blue plastic tab is a shipping tab,
grab it with pliers and pull straigt out..
remove all the blue tabs
Oct 04, 2009 | Maytag Refrigerators
Water filter compartment leaking
If you have already replaced the filter and you can see the housing is still leaking, You have to replace the housing and water tank as an assembly (12956202). Make sure you verify it's the filter housing leaking, and not a fitting at the water valve which is right behind the plastic cover around and below the filter housing.
Apr 28, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Have Maytag Model #MER5765Q - Door handle came off (slight weight on it caused it snap off). No broken/sheared bolts or broken plastic. Can't figure out how to reinstall. Help!
u have to take whole door apart to get to it . remove the door then take screws out from bottom and sides then u can removbe the glass to see the other screws helping to hold handle on
Mar 17, 2009 | Maytag MER5765Q CleanDesign Electric...
Where does this part/piece go in the frig?
by process of elimination .....I finally figured it out...
Jul 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
345 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
