Question about Boston Acoustics Audio Players & Recorders
NOS-95. Why does zener diode ZD3 keep burning out?
Posted by Marc on
  • Marc Apr 17, 2020
    Sorry, when I say polarity change I mean adjusting the knob on the back of the sub
Tom Chichester
    Top Expert:
  • Boston Acous... Master
  • 61,130 Answers
You may have to replace the zener with an equivalent having a heftier current rating.
Posted on Dec 12, 2020
1 Related Answer
vogesclive
Clive
  • 882 Answers
SOURCE: Boston Acoustic 5.1 surround, auto-on subwoofer. ZD3 diode fried brown, system works without diode, do I need to put in a new diode? If so, which direction is +.
Re polarity - the diode should have a band nearer one end.
This band is the cathode.
Usually labelled k in schematics.
The un-banded end is the anode.
Usually labelled a in schematics.
On a standard rectifier diode:
The positive + supply enters the diode at the anode and exits at the anode.
However, the component's ID is ZD3, which tells me that this is a Zener diode.
A zener diode is connected opposite polarity to a standard rectifier diode, as it only conducts when reverse voltage from k to a exceeds a pre-determined level.
This is probably part of a voltage regulation or voltage clamping circuit.
ie: when voltage on 'k' line which is positive goes above 'X' volts the zener will conduct, shunting voltage to ground or another part of circuit.
So on ZD3, band is +.
A new diode is advisable, as it serves as over-voltage protection.
The caveat is what voltage rating of zener diode you will need.
A schematic of the sub will be needed to know this....
Posted on Nov 27, 2017
How do you repair blown Boston Acoustics Subwoofer MCS Amp?
Most often this unit goes dead because of zener diode ZD3 shorting. It is a 18v zener. replace this and you should be back in business.
Feb 20, 2017 | Boston Acoustics Audio Players & Recorders
Sub woofer not turning on
Is it receiving power? If not that is your answer - could be a blown fuse, bad wire, bad connection, etc.
If power is there and it still does not work then the problem coud be with a bad sub woofer on/off switch, internal fuse, or worse, blown amp from over driving.
Feb 25, 2016 | Boston Acoustics MCS 90 Horizon Series...
Hi i have the Boston acoustics soundware xs 5.1 the sub stopped working the led shines red on stand bye and turns to green when the amp is switched on so i have taken it apart and found ZD3 has blown but...
ZD stands for zener diode and used for exact voltage regulation. Take out a known good one and go to a repair shop to replace. Make sure that when you re install, the striped (polarity) markings are in the same direction!
Mar 14, 2014 | Boston Acoustics SoundWare XS 5.1 Speaker...
My Boston Acustic subwoofer connected to my Denon Avr 1312 is not turning on the les light on back of subwoofer dobt even come on had fuse checked but its not blown.
There is a common problem with a zener diode in that amp that goes bad. ZD3 is a 18v zener and it goes short. Sometimes R9 on the back will open when this happens. Need to have them replaced.
Oct 09, 2013 | Denon AVR 1312
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
I also have a fried zd3 on my boston acoustic mcs 95 Sub amp board. Do you know the radio Shack part number you used and did your amp power up? My Sub is not working. No power and no green light but my...
zd3 is a zenna diode, you will need to find the volts that it triggers at, most amps (99%) have a mirror circuit board so all components are dobbled so this will help you find what you need Re: Jeff
Nov 25, 2012 | Radio Communications
Mcs 160 subwoofer no power
I had the same problem with my subwoofer unit. I found the zener diode ZD3 was fried. The pic below shows the diode and its clearly tagged ZD3. You need a multimeter to check this before you order anything. This diode should only transmit power in one direction. Its size and spec is 18v .5w zener diode. (that's 1/2 w) It's very inexpensive and the whole repair took about an hour. This is from a Boston Acoustics subwoofer MCS 160
Ok..the procedure is easy.
1) unplug the unit and bring it to a well lit work area.
2) remove the panel from the back and locate the board that is held to the panel by 4 screws and has the ZD3 diode. The pic below shows the diode at the end of my test lead. Note the direction of this part and reinstall the new one in the same direction. Its a simple de-solder and re-solder project. I elevated the new diode about 1/8 " from the board with a small strip of copper. This acted as a heat sink during the soldering and elevated the part above the board to help it dissipate heat later when in use.
3) re-install the board and plug in all the connections.
4) this worked for me and I'm enjoying my sound system again!..good luck0482b949-8492-43a6-91df-0fb2f0e6888b.jpg
Jul 24, 2012 | Denon Audio Players & Recorders
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Replaced the ZD3 on the Boston Acoustics Soundware xs 5.1 subwoofer with a 18 Volt-1 Watt Zener part number 1n4746a. and works like brand new.
May 27, 2012 | Boston Acoustics SoundWare XS 5.1 Speaker...
Burning and fan type sound
That is probably the power section about to fail. The burning smell is going to be from overheating components. You will have to take it into either an akai repair depot or a local tv repair and have it looked at. Get an estimate first. The repair cost on this could be cheap if itis obvious and the repair gys are on the ball or it can be pricey if they just replace major parts (typical). Also have a good idea of what replacement cost is so you know if it is worth fixing.
Jul 20, 2010 | Akai LCT42Z6TA 42 in. LCD Television
Cambridge Soundworks Basscube 12S only makes pulsing buzz noise
Hey! So i fixed my problem! This is for the BassCube 10
Like i said before i saw that the circut board was burnt near the diodes ZD3 & ZD4, and the resistor R63. Thanks to Deadly1 and BillRad62, i figured it out. The R63 is a 1200 resistor, and the diodes are 15v zeners. I went with 3x 5.1v zeners to replace ZD3, unfortunately Rip-Off-Shack (Radioshack) didnt have 3 packs of these so for the ZD4 i put a 12v and 5.1v. Which exceeds 15, but seems to work without a problem. Hope it helps!
Dec 13, 2008 | Cambridge Soundworks BassCube 12 Speaker
93 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
