SOURCE: Squeaky Washing Machine
There are many possibilities but a common one is a worn out idler wheel.
SOURCE: DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
SOURCE: Steady squeaking noise after taking foot off accelerator
sounds like you have a pad rubbing on a disk/rotor, if you jolt the brakes does the noise go away? if so it's probably a pad loose
SOURCE: Washing machine squeak
Same squeak on spin -LW8203 shortly before that she ran an off balance load and now wonders why it squeaks..
SOURCE: hotpoint dryer squeaks at regular intervals
Slow squeaking or scraping noises are often from the rear bearing behind the square panel, the rear bearing
sleeve is inside the middle of the heater housing and the shaft part is attached to the
back of the drum by a "C" clip which needs to be removed first.
The disassembly slideshow is here:
Slideshow
