Computers & Internet Logo
Question about Nuance Computers & Internet
How to install Nuance dragon naturally speaking Customer Service?
Posted by McAfee Activation on
Attique-ur-Rehman
    Top Expert:
  • Nuance Master
  • 2,677 Answers
Solution:
  1. Open Dragon NaturallySpeaking.
  2. Go to "NaturallySpeaking > Advanced > Manage Users."
  3. Click on "New".
  4. Enter a name for the user (e.g., John USB).
  5. From the Dictation Source drop-down menu, select "USB Microphone".
  6. Click on "Next".
  7. Follow the instructions in the Audio Setup Wizard to train the user profile.
http://nuance.custhelp.com/app/answers/detail/a_id/2389/~/how-do-i-setup-a-usb-headset-microphone-with-dragon-naturallyspeaking%3F
Posted on Apr 17, 2020
What is a serial number to install dragan 11 to my Labtop
You can buy one on nuance.com website or even on Amazon and ebay.
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
Can Dragon 10 be installed on Windows 7, 64 Bit?
Apparently you need update 10.1 to work on a 64 bit system. Check this out: http://community.nuance.com/blogs/dragon/archive/2009/03/25/dragon-preferred-and-standard-10-1-updates-for-vista-64-available-in-english.aspx
I just bought naturakl speaking 11.5 home. how do i download it/
Dragon Naturally Speaking 11.5 FULL
If you already have a premium key,
Click here
Trying to use the headset provided by Dragon 11 naturally speaking software. The headset has two jacks, a mic and a headphone one which I have set up via RealTek, although I cannot get playback on the...
Did you check the installed sound devices on the computer?
May be you do not have any sound driver installed on the computer,
Also check the device is not disabled from the control panel.
If you did not find the solution helpful. Try to search for the solution here... this has many solution to this problem.
Nuance and Dragon Naturally Speaking Support
1helpful
Top Nuance Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Larry Ng
Larry Ng
Are you a Nuance Computer and Internet Expert? Answer questions, earn points and help others
