SOURCE: maytag washer goes off balance
Several shock absorbers are used to internally balance the basket. Most likely they need to be replaced. It is a typical malfunction. Not expensive and can be done quickly by experienced DIY guy.
SOURCE: FAV6800AWW MAYTAG NEPTUNE
If you are sure that the load sensor is not the problem then you really need to get a service person to try to correct. The side rotators should not be moving.
SOURCE: Out of balance
have the snubber ring replaced
the reason i say HAVE IT REPLACED is to get to the snubber ring the machine has to be dissasembled and requires special tool to get it apart and back together
SOURCE: Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
