Question about Kenmore Refrigerators
Kenmore elite freezer not freezing, refrigerator is cool not cold and maxxed out on settings. Temperature sensor gone ?
Posted by jeff on
ray gallant
    Top Expert:
  • Kenmore Master
  • 71,004 Answers
MOST LIKELY FREON HAS LEAKED OUT
Posted on Nov 14, 2020
Food freezing in refrigerator
There has to be a balance between the freezer and the refrigerator because the refrigerator gets its cooling from the freezer, if you set the freezer to cold, the other side freezes,
Feb 17, 2014 | Kenmore Refrigerators
I have Kenmore Elite 59673503201 freezer fan went out replace then it started freezing at the bottom of the refrigerator put in new vent control at the top of refrigerator still doing the same thing
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 17, 2012 | Kenmore Refrigerators
The freezer on my Kenmore Elite Trio has stopped freezing. All my food is thawing. How do I set the freezer temperture at the coldest setting?
If the temperature is the problem this could be the solution
Problems with Temperature
If the refrigerator or freezer is not cooling properly, check temperature settings and air vents and ensure there is adequate room for proper airflow. Factory-recommended temperature settings are 0 degrees Fahrenheit (-18 degrees Celsius) for the refrigerator; and 37 degrees Fahrenheit (3 degrees Celsius) for the freezer.
If you need to adjust the temperature, do it one degree at a time and wait 24 hours before making additional adjustments. Check the air vents and make sure nothing is blocking them. Finally, if your refrigerator or freezer is too full, there will not be adequate room for air to circulate and cool properly. If these all check out, the problem could be with one or more compressor components and will require professional repair.
Hope this will help you.
Thanks for using FixYa : )
Sep 08, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
Kenmore elite refrigerator. both compartments (bottom freezer and top refrigerator)are not keeping with the temperature setting. the food is cool but not cold as it should be. how can I test to see if...
Really most folks have to keep their setting on their fridge on about a 6-7 or-8 setting with the amount of food that is kept in the fridge now.
YOU CAN KEEP AN EYE ON THE RELATIVE temp if you like by placing a fridge thermometer in the appliance. Optimal fresh food should be around 40-43 degrees F on average to keep things on the cooler side without freezing.
Hope this helps
Nov 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Nov 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
85 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
