SOURCE: Lg shine, camera problem. UPSIDE-DOWN! help
Try pressing one of the arrow up or down keys on the side of the phone while in camera mode. Sorry if I'm wrong, I'm not sure about LGs but that's how you do it on Samsungs.
SOURCE: my projoctor picture is upside down
http://www.manualnguide.com/dl/14476/
There u will find the manual for your projector, read it and follow the steps how to tunt the picture up and down.
Good luck
SOURCE: Upside down display
it could be a number of things. One, it could be your graphic card settings, have a look at them. Two, i forgot but therer is a shortcut to maing your screen turn upside down. Have a look at the settings and i hope you find how to fix it.
DigicalJAi
SOURCE: Numbers are upside down. How do I turn them around?
Frankly, I would love to see that. More seriously, now, if problem is software related you may be able to recover you calculator.
Use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there.
Install TI connect on your computer and run it to open the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. It will try retrieve the info.If it does your calculator is fine. Fill the screen with letters, symbols, numbers, and use TI connect ScreenCapture icon and compare the image with the actual screen. This may serve as a diagnostic tool in case you have to take calculator for repairs.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and try OK. If you are lucky and it works, you should reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the OS of a working calculator. Yous should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator, you guessed exactly right, must be on Send [2nd][Link][SEND][G:SendOS]. (When both calculators are ready hit [ENTER])
If all that does not work, then it may be time to head for a place of worship to pray for its resurection, or look for a repair shop.
Hope it helps
