Question about Garden
SOURCE: yamaha dt 200 won't rev off idle
You should measure the combustion ratio.Maybe piston rings failed.
Posted on Jun 03, 2009
SOURCE: 1989 Chevrolet C1500 with 5.7L V-8. Engine dies
fuel pump is working but when accelerating it doesnt pump enough fuel up to the engine then it will fall on its face if it is a electric pump you may have to drop the tank if it is inside and replace it if it is on the engine replace it thats what is exactly wrong with it
Posted on Jul 31, 2009
SOURCE: Engine starts easy. Engine can only achieve high
eitrher a clogged fuel filter thats in the tank, old gasoline or the fuel pump daiphragm in the carb has hardened
Posted on Oct 31, 2009
SOURCE: Keihin CVK-D36 carbs on a 20 yr old ZZR 600
It sounds like your bike has been sitting in storage for an extended period of time (a year or more) - and the carburetors are plugged up. If this is the case, they will need to be completely disassembled and cleaned out.
If it hasn't been sitting (and the carbs aren't plugged up) then check that all of the normal tune-up items have been performed, especially valve adjustment, oil and filters, spark plugs, etc. If this fails to produce positive results, perform a compression check on the engine. Each cylinder must be able to produce at least 140 psi of compression in order to run and idle properly.
Posted on Nov 07, 2009
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Mar 05, 2015 | 2003 Harley Davidson XLH Sportster 883...
Oct 13, 2014 | Motorcycles
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Jun 29, 2011 | Echo Gas 20 In Blade Double Reciprocating...
May 28, 2011 | Hardware & Accessories
Jan 08, 2018 | 1997 Geo Metro
Jun 29, 2010 | Electrolux Poulan Pro Gas Chain Saw...
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
69 people viewed this question
