Question about LG Audio Players & Recorders
My home theater LG DVD player HD6530 displays GOODBYE and shuts down.
Posted by UMEH CHIDIEBERE E on
Boss123123
  • 3 Answers
Hahhaa, I recommend you to throw it out.
and check out problem here on triveditech
https://www.triveditech.com/
Posted on Apr 13, 2020
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Posted on Jan 19, 2008
Anonymous
SOURCE: Insignia 5.1-Ch. Home Theater System w/5 disc changer
when I press dvd it msg comes on
Posted on Dec 23, 2008
Anonymous
SOURCE: samsung dvd home theater HT d5610
I am looking for and to purchase an antenna for my HT D5610. Thank you for any help you can provide me with.
Posted on Feb 01, 2009
SOURCE: Unlock Region Code for LG XB12 Mini Home Theater
Below is the only known process to unlock the region settings on that model of dvd player.
Make sure there is no disc in it
Turn on by pressing "Power"
(--------) apears an "No Disc"
Press "Pause" on remote and "314159"
"Code" apears
Press "0"
"Code 00" apears
press "enter"
Turn off and on
Hope this works for you, let me know. If it doesn't then there are no available region hacks for your dvd player.
Thank you for trying Fixya!
Posted on Mar 25, 2009
Anonymous
SOURCE: SYSTEM SHUTTING OFF
I had the same problem and of course my system is out of warranty. If you open the system up most likely you will see portions of a board near the fan burned up.
Posted on Jun 18, 2009
My home theater LG DVD player HD6539 displays GOODBYE and shuts down.
There are several reasons that this could happen and given the cost of a new one VS the experience you need and the tools and test gear, it would be best to get another one.
Could be a sticky power of function key, bad laser, bad motor, bad power unit, bad detector
Tray will not open on coby 978
Sorry, but my experience with CD, DVD players and recorders has taught me that, once the trays refuse to open, the unit is history. Kiss it goodbye. . .
1helpful
Philips hts 3265
hi,lg lh d6230a home theater player display show the dvd error but not opening cd room .why this wrong please help me.send me reply
READ CD BUT NOT DVD NO DISK Disply
you need to replace the laser assembly in the drawer laser is going out
JVC TH-G30 automically turns itself off after 5 seconds
Need help guys. Jvc thg30 turns on then after several seconds displays goodbye and turns off
10helpful
3answers
My LG ht303su dvd player won't eject and it says it's locked
my LG ht303su DVD player won\'t eject and it says it\'s locked
8helpful
Fan chk problem too
it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
My dvd home theatre system ht tx75 keeps shutting down
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
Top LG Audio Players & Recorders Experts
 Francisco Mauricio...
tina gallow
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
