Question about Kenmore Refrigerators
Kenmore refrigerator model #106.51792, had power surge hit my house, now frig only cooling bottom of freezer and frig. What part needs replaced?
Posted by Grace Aiken on
Arnie Burke
  • 6,523 Answers
Som relay or switch cudda gut fried..unplug it for fewmin n see if anything clears..if not ull need tests done by atech. If its an old unit umay b bettr off replacin cause itll b anothr part down road$
Posted on Apr 13, 2020
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Model 795 77304600 bottom freezer purchased dec 06
WHAT IS WRONG WITH YOUR FREEZER?
small_3_29.jpg For a detailed Freezer illustration, click below.
Chest
redarrow.gif Upright
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It doesn't work at all
It's not cooling
It cools poorly or it's all iced up
It's noisy
It doesn't cycle off
Hope this may help you;
Regards,
VOTIT
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Stopped cooling
My refrgerator a Kenmore, model 106-71182101, with ice maker stopped cooling and freezing.I vacuumed the condenser coils, and
fan in the rear bottom, along with any other debris. I unplugged the frig because the compressor was very HOT!.Question? Could the compressor have a Locked-Rotor? If so what can I do to loosen it.
Apr 08, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
I have a water leakage coming out the bottom of my kenmore refrigerator model 52559100
check your defrost drain line. can be located in freezer section. also if you have a filter at the bottom make sure the housing is not cracked. If your frig is cooling then the coil is going to be doings its job
Jun 08, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
We have a Kenmore side by side model 52584201. Yesterday the freezer side stopped working. The refrigerator still cools. I have checked all the vents and cleaned around the vent at the bottom. Any ideas,...
FREEZER IS WHERE THE FRIG GET'S COLD AIR. IF BY NOW YOU HAVE FOUND THAT THE FRIG IS INOPERATIVE. CHECK THE OVERLOAD RELAY ON COMPRESSOR. HAD TO REPLACE ONE ON MINE PART WAS ABOUT $60
Feb 26, 2010 | Kenmore 52582 / 52584
Cooling and freezing problem
When the frig stops cooling properly, is it running at all? If the freezer fan is running and it is not cooling, you can rule out the thermostat and the defrost control. It would be a hard starting compressor or condenser fan. If the frig is not running, then it is likely the thermostat or your electronic defrost control. The defrost control is right behind the thermostat in the same housing. When you play with the Tstat, do it carefully as not to jar the defrost control. If the frig comes on, replace the thermostat.
Mar 23, 2009 | Kenmore Refrigerators
Kenmore Model #253-64802400
IT SOUND AS THOUGH THE COMPRESSOR IS NOT RUNNING. IF IT IS AND YOU HAVE NO COOLING, THEN YOU HAVE A SEALED SYSTEM PROBLEM AND WILL NEED A SERVICE TECH. IF IT IS NOT RUNNING, UNPLUG IT AND REMOVE THE RELAY AND OVERLOAD FROM THE SIDE OF THE COMPRESSOR. MAKE NOTE OF WHERE THE WIRES CONNECT AND REMOVE THEM. NEXT, SHAKE THE RELAY AND LISTEN FOR WHAT SOUNDS LIKE A BUNCH OF SMALL ROCKS IN IT. IF YOU HEAR THIS, THE CERAMIC DISC IN THE RELAY IS BLOWN AND YOU NEED A NEW ONE. IT IS POSSIBLE FOR THE POWER SURGES TO BLOW THESE DISCS.
Jan 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer stops freezing food - frig stays cool
Possibly sounds like the heating element on your defroster is burnt out or the drain hole for the defroster is blocked, not allowing the defrosted water to drip underneath the fridge to evaporate, thus causing a buildup of ice. That buildup may be blocking that vent that goes bwtn the freezer and fridge. The heating element is simply checked and/or replaced by removing back panel of freezer. It's about the only thing behind that panel and likes like a row of fins. Google images for a better understanding of what you are looking at. If its a block of ice, you know there is a problem. The element is replaced by simply unplugging it and replacing with a new one. You should also see a small hole at the bottom of the freezer. Try pouring a little water in it and listen to see it its running into the plastic pan that's underneath the fridge (usually visible if you take the grill off). Some models have a hose that kinks up attached to this small hole. Had an Amana freezer that did this on several occasions and cause the whole bottom of the freezer to become a block of ice because the water had no where to go.
Apr 17, 2017 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Quit, but has power 106.56563400
is the compressor hot? if yes, unplug , let it cool, and replace relay assy.
Oct 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
