Question about Euro-Pro Sewing Machines
Try removing bobbin and hook race and if it makes noise without, then you'll need to open it to lubricate upper and lower shaft bearings.
If noise goes away with hook removed be sure to lubricate per manual. Use a good synthetic machine lubricant such as gun (firearm) oil.
See link for operators manual
http://diplo-best.com/314.php?k=977b3b8eab3039c470c4ebb0c8af9c02&ID=815028&q=EURO-PRO%208135H
Posted on Apr 12, 2020
I'll give that a try and see if that gets me anywhere. If not I may have to get the poor thing serviced. Which sadly will have to wait till the sewing shops are open again.
So come to find out it was gelled lubricant on the main drive shaft coming from the motor. Luckily I had some lucas gun oil (the blue stuff, the red is far too sticky) and gave it a good oiling. I also went through while I had the case off and hit every oil port with a touch and now it is whisper quiet. Thanks for leading me in the right direction!
you may have to email these sites to locate the part
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
Posted on May 21, 2012
