Hi
My sinqtec smart tv was working fine until this morning there was no wifi connection so I selected forget network and now I cant seem to pick the network back up...it keeps telling me not in range...please help
Https://www.youtube.com/watch?v=yIUxiI3YwCw
https://www.youtube.com/watch?v=_84oc-xZtWo
SOURCE: manual network selection
1. Press the Talk button to bring up the call history/dialpad. Now press Menu (at the bottom right hand corner) and select Options. Go to Network tab and select Manual under Network Selection.
2. Tap Start >> Settings. Tap on Phone option in Personal tab, go to Network tab and select Manual under Network selection.
SOURCE: Please email me tv manual of this tv sinotec smart tv 43 LED STL - 43E 390M full he 1080
Your email ID?
SOURCE: Sinotec smart tv no sound remote stuck on 0
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
http://electro-medical.blogspot.com/
why post this to computers and not TV
why make answers slow or wrong or none.
off topic this.
post to television
ok?
https://www.fixya.com/troubleshoot/brows...
wifi
at home,work or starbucks.
where are you.
if at home then do other things work there wifi. we can no know prime questions.
my cell phone even can use wifi, I use it all the time, to save on data charges .
so does yours work
or does PC work at home on wifi
is this your router is belongs to the ISP
no ISP told.
you call the IPS and they tell you to reset power to the router wifi.
then it works.
if not learn your credentials to you wifi
then write them down.
SSID - rover1
password= 123456 (both fake, as example)
only you know them. nobody else unless the ISP put it there, that router and told you all this. if yes, ask then again.
