Video Cameras Logo
Question about Panasonic Video Cameras
I have a panasonic sdr h85 i was wondering if there was any way i can record without picking up sound
Posted by malcolm hendry on
Attique-ur-Rehman
    Top Expert:
  • Panasonic Master
  • 2,677 Answers
Https://books.google.com.pk/books?id=S_gjI7Gg3IQC&pg=PA140&lpg=PA140&dq=panasonic+sdr+h85+i+was+wondering+if+there+was+any+way+i+can+record+without+picking+up+sound&source=bl&ots=kFAJurZxv3&sig=ACfU3U0Tx7pdbg_1AxeYGxEafwjuyvJptQ&hl=en&sa=X&ved=2ahUKEwikwvu5oN7oAhWvDWMBHaCSCu8Q6AEwAHoECAwQJQ#v=onepage&q=panasonic%20sdr%20h85%20i%20was%20wondering%20if%20there%20was%20any%20way%20i%20can%20record%20without%20picking%20up%20sound&f=false
Posted on Apr 10, 2020
I have a Panasonic Camcorder SDR-H85 and I have lost the charger
I shall only reply to one of the multiple queries you have made on the same subject.
I would suggest either the mfr, or Ebay.
I would also suggest you take better care of your possessions.
I have a Panasonic SDR-T55P video camera. The battery seems to be good but the unit turns off immediately after the viewing window is open (red light is on for a few seconds). Any advice?
WHAT MESSAGE IT DISPLAYS ON SCREEN? OR WHAT IS THE RED LIGHT? IS IT THE SAME WHEN IT RECORDS?REMOVE SD CARD AND TRY USE EXTERNAL POWER SUPPLY BUT BATTERY MUST BE PANASONIC ONLY AS I SEE IT ON THE MANUAL HERE...About batteries that you can use with this unit
SDR-S50
SDR-T55
The battery that can be used with this unit is VW-VBL090/VW-VBK180/VW-VBK360.
SDR-H85
The battery that can be used with this unit is VW-VBK180/VW-VBK360.
The unit has a function for judging whether the battery can be used
SDR-H85
safely, and only dedicated batteries (VW-VBK180/VW-VBK360) support this function.
Only batteries which are genuine Panasonic products and batteries from other
companies certified by Panasonic can be used. (Only batteries which support this
function can be used) Note that Panasonic can only guarantee the quality,
performance or safety of genuine Panasonic batteries and not those made by other
companies.
It has been found that counterfeit battery packs which look very similar to the
genuine product are made available to purchase in some markets. Some of these
battery packs are not adequately protected with internal protection to meet the
requirements of appropriate safety standards. There is a possibility that these
battery packs may lead to fire or explosion. Please be advised that we are not liable
for any accident or failure occurring as a result of use of a counterfeit battery pack.
To ensure that safe products are used we would recommend that a genuine
Panasonic battery pack is used
The unit has automatically detected an error. Restart
the unit by turning off and on the power.
? Repair is needed if it is repeatedly displayed even if
it is restarted. Detach the power connected, and
consult the dealer who you purchased this unit from.
Do not attempt to repair the unit by yourself.
2answers
I have a panasonic sdr h85 i cant download my videos to my computer i do not have a software disk could that be the problem if so how could i get a software
-Are you using a memory card? Check "my computer" for removable drive and look for folder(s)
-Are you direct connecting via usb connection?
May need to wait for driver(s) to load to enable viewing.
What windows are you using?
Try this page: http://www.megaupload.com/?d=2U85KF1Y
Click on "Regular Download"
It's a .rar file so you'll need winrar to decompress it. Send me a personal message if you need help.
How to delete files form my sdr-h85
you will need to connect your camcorder to your computer
click start click on my computer to open from there you should see your camcorder then right click to select open you should see the data/files in there select what you want to delete right click select delete or you can right click select format this will delete all data on hard disk
hope this helps you
Sound Recording problem
Don't know if your problem exactly like mine, but playing back recordings in the camera always have weak sound. However when editing the clips using Imagemixer 3 on your computer, the sound is louder and you can boost it even further with the "Adjust Volume" function of Imagemixer.
Bernie
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
