Televison & Video Logo
Cesar Pelarca Posted on Apr 10, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have sony KDL 32EX520 No picture but sounds ok.
Attique-ur-Rehman
Level 3:
Top Expert:
  • Sony Master 2,677 Answers
  • Posted on Apr 10, 2020
Attique-ur-Rehman
Sony Master
Level 3:
Top Expert:
Answers
2677
Questions
Helped
878122
Points
8006
Https://www.youtube.com/watch?v=MQj2t4nNVYc
How to perform a power reset on a Sony television. ... Turn on the TV, then make sure that the indicator does not blink (which means the TV has no issues). Connect the disconnected devices one by one to the TV. If the indicator starts blinking after a certain device is connected, check the device for a issue.
https://www.sony.com.sg/electronics/support/articles/00153674
5 Related Answers
Anonymous
  • 157 Answers
  • Posted on Oct 07, 2009
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Anonymous
  • 29 Answers
  • Posted on Jan 25, 2010
SOURCE: Sony Bravia. kdl-32l4010
no ,ur tv got a problem inside.better to bring it in shop
Anonymous
  • 178 Answers
  • Posted on May 07, 2010
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Anonymous
  • Posted on Aug 05, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
barbu51
Jacques Marin
  • 566 Answers
  • Posted on Sep 24, 2010
SOURCE: Sony KDL-42V4100 has sound but no video. Input
Hi there
this is not meant as a solution, but a tip if you`d like to get an answer.
You should clarify in which occasion you get either sound and no video or black screen with sound.
This is a little confusing for a repairman.
2answers
Sony bravia standby light blinks 3 times kdl-32ex520
Hi my sate problem 3times red light blink and sum time is OK no problem 46bx450
SONY KDL-32EX520 Left Half picture normal Rihgt half white. what problem?
Dear
normally its panel problem but some time in t con board is defective so please first change t con board if your problem not solve then replace panel
thanks
M Nasir
Sony bravia KDL 40S4100 No picture
If you wish to get some details; check the site linked here. Pull up older posts.
Troubleshooting procedure for No-Picture is given in detail.
1helpful
Picture absent sound ok
Check and replace its back-light inverter board. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
1helpful
2answers
Kdl-32ex520 7 time blinking
seven times blinkings means need to change or replace main board .
Panel issues with sony kdl-hx800
That sounds like a defective LCD panel tab connection. Does it go away if you tap the left side of the set? Or does it clear up when the set warms up?
I could not connect to internet with my sony bravia kdl 32ex520 I am using the ethernet cable( no modem) when i check the status it is showing as cable is connected and internet is failed error 1106 i...
Ethernet connections between the tv and the computer into one signal frequencies are not compatible signals.Ur main home computer have internet service connection go through a wire or wire less Router for a internet signal through out the house.Connect the tv internet signal through the Router.Internet signal will work fine.
2answers
Sony bravia model kdl-46z4100 has no sound. picture is ok.
Tries tv unplug,replug it back about an hour later for the tv for a resetting back to the factory setting.Go into the tv menu go to Audio Setting go down to do a resetting back to factory setting.These steps will help the tv to get the tv audio back.
9helpful
Sony bravia kdl 46s4100 no picture
Sound ok no picture
If it is connected to a cable box with an HDMI cable, try connecting up component instead
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
