SOURCE: oven trouble
I had this same problem with my range. It ended up being the thermostat that maintains the temperature in the range itself. This should help. The thermostat will usually have to be professionally replaced, it is too risky to be done by a novice so call a shop for help.
SOURCE: I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
SOURCE: The blower fan comes on several minutes before the
Bad fan switch. It may also be called a fan limit switch. If your furnace is less than 5 years old, the switch is part of the circuit board and you will need to replace the board.
