Question about Amana Cooktops
Amana cooktop Model ; AKED3060SS, I need following replacement part: Fan/motor assemblay
Posted by Louis Castonguay on
2 Related Answers
gerbee gomez
  • 222 Answers
SOURCE: Need part d8598902 for cooktop
gud day,depend how long ur unit it is? do u think if u replace the said parts is the unit is still ok,call the service center to inquire give the model no of ur unit to verify.
tnx gerbee
Posted on Sep 16, 2009
Anonymous
  • 69 Answers
SOURCE: i need a dual burner switch for my Amana cooktop model ak2h30hr
Fit two switches. Although this might be as expensive as a new cooktop.
Posted on Mar 27, 2010
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
I need a dual burner switch for my Amana cooktop model ak2h30hr
Mar 27, 2010 | Cooktops
Apparently this model is no longer being made?? Is there a way I can still get replacement parts? like a new grate, tray and caps?
you can call amana located in the colony's in IOWA i used to haul there units from coast to coast and if anyone has replacement parts it would be them!
Jan 20, 2010 | Amana 30 in. ACC3660 Gas Cooktop
tnx gerbee
Sep 14, 2009 | Cooktops
Electric cooktop burner is always on hi when it's on
I just wanted the name of the part and possible sources. Not worth paying $14 for.
I found it else where.
You should give your prices up front, before users spend any time trying to use your site.
Jun 10, 2009 | Amana AKT3040 Electric Cooktop
Amana Electric Smoothtop Cooktop heat control knob.
1st remove the control knob by off position & pull it one by one then clean it by using vacium.tnx
Nov 16, 2008 | Amana Cooktops
Clearence to hood fan
I just had a similar cooktop installed with a micro over it. From the bottom of the upper cabinet to the top of the burner frames you need 33 1/2 inches and from the bottom of the micro to the burner frames you need a minimum of 16 1/2 inches.
Aug 01, 2008 | Amana AKS3040 Gas Cooktop
Cooktops Logo
81 people viewed this question
Top Amana Cooktops Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
