System spec:
mobo: asus k8s-la 754socket
old cpu: amd athlon 64 3400+ 754 socket (cpu label code: ada3400aep5ar)
new cpu: amd athlon 64 3400+ 754 socket (cpu label code: ada3400aep5ap)
The other day, there was a problem
with my heatsink. When i turned on my computer for about 15 minutes, it
would get overheat and turn itself off. when i open the case up and try to clean the heatsink because it was filled with dust and dirt. Upon doing that i damaged the cpu because it was stuck tight to the heatsink like superglue. I end up getting a new CPU. but now nothing is booting up except the solid amber light. The only thing that came on was the PSU fan.
Here's what i did so far:
reset cmos
benchtest
reseated rams/video cards
replug all the cords
but still no luck. I'm thinking its the mobo. any suggestion would be apperciate.
Thanks
Bad power supplies, motherboards, and front panel connectors have plagued this model since Dell started selling them. I had the same model and after 3 motherboard replacements, 2 front panel fixes, and 3 power supplies it still only worked sporadically. In reality only Dell tech Support has the answer to the specific code as they do not publish them. After much research found out the design was flawed. You can try to keep fixing or you can go the route I did and cannabalize the RAM, video card, hdd's, cpu, & optical drives and purchase a barebones kit that is compatible with your parts. I found one for mine for less than $200. Hope this helps.
I think you have damaged a pin or something on motherboard and fried it
never ever force something of a computer especially the motherboard becasue everything is linked to it i accsidently dameaged the motherboard on my last computer it fried the power suppy.
your problem was not the heatsink its the fan thats the problem in your pc you need better circulation you should invest in better fans on the case and make sure its not graphics card thats overheating you can do it with many free apps from sites like majorgeeks
e.g. i use coretemp for cpu and i ot a built in one for graohics card
all the heastsink does is draw heat from cpu never clean it becasue its not worth the risk becasue it dosnt really do anything
id recomend taking everthing out of the case and putting all the components on your kiturn table and see which fans come on(there are fans on all major compnents)
i hope this has helped you if not feel free to mail me on
[email protected]
