Question about Konica Minolta Office Equipment & Supplies
Dear my freinds thank you for helping us to solve the troubles. Second let me put my question firs I had a konica minolta bizhub c454e and it is printa outs only black and white not colour so what is the trouble
Posted by mohamed on
Attique-ur-Rehman
    Top Expert:
  • Konica Minolta Master
  • 2,677 Answers
Click File > Print to open the print window. Choose the Konica Minolta copier next to Printer. Click Copies & Pages - choose Quality from the list. Under Select Color, change the setting to Gray scale.
https://services.dartmouth.edu/TDClient/1806/Portal/KB/ArticleDet?ID=64787
https://community.spiceworks.com/topic/235669-how-to-make-konica-minolta-print-only-black
Posted on Apr 06, 2020
  • mohamed Apr 07, 2020
    We have made all of that options I have selected colour but still prints out black and white
5 Related Answers
Anonymous
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
taminol
taminol
  • 62 Answers
SOURCE: minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
Posted on Jul 27, 2009
Anonymous
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
I have trouble code c1139 on konica minolta
There is a fault on the shutter system. The fault will keep returning until you fix the fault.
Apr 13, 2018 | Konica Minolta Office Equipment & Supplies
I have a konica minolta bizhub C454e I want to insert the IP but when I enter the administrator option I can not find the Network Settings ... what can I do?
You can try trouble reset.
First you need to switch off the copier, then hold the yellow reset button and then whilst holding it power up machine. Hold reset until you get white screen with trouble reset in middle. Now tap on the trouble reset button and it hould point down an arrow saying OK. Now shut down the machine again and leave it off for at least 10 seconds. Boot up machine and try to access the network settings.
If this doesn't work then you may have to call a service engineer to reset it in Service mode.
Sep 23, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Trouble code c2551 on konina minolta bizhub c454e
c2551 come when Cyan low toner in Cyan Developing Unit.
Try to reset by opening and closing front door.
and check toner supply-hopper
if not still ok then replace Cyan Developing Unit.
Nov 30, 2016 | Konica Minolta bizhub Office Equipment &...
Where can this part for the printer be purchsed ? konica minolta bizhub 160
Except you don't say what 'this part' is :>)
Never mind. Here you go. Or look in Yellow Pages for a technician.
  • Konica Minolta bizhub 160 Supplies and Parts (All) www.precisionroller.com > ... > Konica Minolta > bizhub 160 Konica Minolta bizhub 160 Supplies and Parts (All) for less. Free shipping on orders over $75.00!
  • Konica Minolta Bizhub 160 Toner, Parts, Supplies, and ... www.arcservicesco.com/1016/konica-minolta-bizhub-160-i-toner-parts... Additional Info Konica Minolta Bizhub 160 is a Digital Printer and Copier which was introduced February 10, 2012. Suggested Retail Price:$1,029
  • images of konica minolta bizhub 160 parts bing.com/images th?id=oip.mcd31c057681b6e2e393bc136df5885ddo0&w=140&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m850c92a4f48e9107608f3f81e06b2feeo0&w=99&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mdb0ced5306197a197806530dbb355967o0&w=74&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mb7d2a296bf50d1a0bb42098505ce2c61o0&w=133&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.maedc8ec17eba695445679a648922e7e3o0&w=70&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of konica minolta bizhub 160 parts
  • Konica-Minolta bizhub 160 160f 161 161f Parts Manual www.qmanual.com/printer/konica-minolta-1/bizhub/konica-minolta... BRAND: KONICA-MINOLTA: BRANDSKU: No: TYPES: Parts_Manual: SIZE: 1.49M: PAGES: 35: FORMAT: PDF: LANGUAGE: English: QUALITY: High resolution: ...
  • Konica Minolta Bizhub 160 Printer / Copier Parts & Supplies https://discountcopiercenter.com/konica-minolta/bizhub-160.html Save big on Bizhub 160. We offer the lowest prices and highest quality, with free shipping on any orders over $100!
  • Konica Minolta bizhub 160 Parts Guide (160_PARTS) www.atec.ro/parts.../konica-minolta-mfps/konica-minolta-bizhub-160... Konica Minolta bizhub 160 Parts Guide; PN: 160_PARTS
  • Apr 01, 2016 | Konica Minolta Office Equipment & Supplies
    Dear sir i have konica minolta bizhub c450 it shows enter serial no call service engineer how can i fix this problem ? thank you
    When this message "Call Service Engineer" appears, then there is also trouble code along with it.You have to just note down the error code, then tell again.It will help to solve your problem.
    Feb 07, 2015 | Konica Minolta Office Equipment & Supplies
    How to solve code C0510 on konica minolta di552
    Open the front door upper left access cover, open press trouble reset if the code comes back do not reset as this deals with fuser can catch on fire will ruin perfectly good day
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
    May 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
    Konica minolta bizhub c450 error code c- d370
    I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
    May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
    55 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    carpediemweb
    Level 1 Expert
    George Mclaughlin
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
