Question about Hisense Televison & Video
Have a Hisense 40H3E tv that the screen went black on (Still has sound). You can see the picture if you shine a light on it. I took it apart and tested the led output with my multi-meter and it gets about 48V out with the strips connected to the board as well as with the strips disconnected. I did a lot of googling and reading of YouTube comments but could not find out what the reading should be for my TV. Does anyone know if this indicates a bad board or bad LEDs? Some more info: When I turn it on the standby light flashes 9 times, one long first flash followed by 8 shorter ones I found no signs of blown capacitors or burns on the board. It started with the top half of the screen going darker first followed by all the screen getting really dark but still visible without a flash light then finally the screen going black and needing a flashlight to see the images. This all happened relatively fast within a night. When I noticed the whole screen go dark I turned it on and off to see if that would fix it. I was able to see the hisense logo just fine but by the time the roku loaded it went dark again. Another power cycle yielded me the black screen with just sound and it has stayed that way since. Does anyone happen to know what the voltage should be to the LED Strips or what I should replace first Thank you!
Posted by AstrosFanHou on
Arnie Burke
  • 6,901 Answers
U can unplug set awhile but may helpit temporarily. Tv is old n worn. Anew one is cheapr then fixn. Think wal*mart
Posted on Apr 05, 2020
2 Related Answers
gopakumarg43
  • 76785 Answers
SOURCE: Hisense tv 55k610gwn, 11 light flashes error code. All leds flash for logo, then no video. Led drive voltage 200+ dc. Power supply or leds?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Oct 18, 2016
vincenttesta
L Vincent Testa
  • 721 Answers
SOURCE: LG TV 39LN5300 - What is normal voltage at LED connection to power supply?
ok so the problem is not with the power suppkly it is with the leds inside the panel they are in strings and usually only a few of them are your problem see the link for led prices http://www.shopjimmy.com/auo-t390hvn02-2-led-strips-8-strips.htm
Posted on Feb 16, 2018
Testimonial: "Had thought that it was the LEDs but with only minimal knowledge was not sure. I don't know why the voltate would be over 200 volts. As for ordering LED strips I have heard that they were panel specific, and have heard that they weren't. The link you provided is out of stock, unfortunately. Is basically any 39" strip useable or does it need to be matched to the panel? Thanks again."
Hisense tv has picture but no sound.
I DON'T KNOW. TRY BUTTONS ON BACK TO INCREASE VOLUME. THIS SHOULD CANCEL 'MUTE' AND TURN UP SOUND. CHECK REMOTE BATTERIES.
UNPLUG EARPHONES IF ANY PLUGGED INTO TV.
Good day. My LG TV suddenly went black. It had sound but no picture. When I tried to switch it on again, it briefly flashed the logo but went black again. Please any suggestions?
Your backlight inverter board is likely bad. If you're handy it is relatively easy to replace. Google for replacement part.
if you can see a picture while shining a flashlight on the screen then it is most likely the inverter board. Backlights provide the light through the lcd screen for brightness.
Codes to upgrade hisense40h3e to a smart tv
There is no code to turn the Hisense 40H3E into a smart TV. This TV doesn't have the network LAN or WI-FI hardware or software. You can only add network streaming by connecting a streaming stick (Roku, Fire, etc.), streaming box (similar items) or use a computer. Most streaming devices connect to the HDMI port; you may need an HDMI switch to share the TV with multiple devices.
Note: the USB port on this TV may not supply sufficient power for some streaming devices. You may need to connect them to an USB power supply to a standard outlet.
I hope this helps.
(the 40H3E does support viewing files from a USB flash drive - see the manual for the list. I found the manual on Manuals Lib here: https://www.manualslib.com/manual/1053975/Hisense-40h3e.html . )
My hisense 40 inch tv won't turn on anymore, not even the red light is on..tried different outlet and even took it apart. model number: 40H3E . serial number: 40M141834H06500
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Hisense TV screen went black after power outage. The name flashes across the screen the sound comes on but no picture
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
1helpful
2answers
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
My Element 32 inch tv has black screened.
hope I dont sound too crude, but have you checked the contrast and brightness controlls ?? they may be labled as 'picture options' or some other odd label...
does this tv have a LED, LCD or the older CTR display ?? If it is LED or LCD, then the light source that illuminates the screen are not working.. this light source could be damaged..
1helpful
3answers
Black Screen
It is possible that the backplane lamps and lamp supply has failed. It is also possible that there is a failure in the power supply or on one of the circuit boards. Without doing some tests it is impossible to accurately determine the areas of fault.
Jerry G.
Televison & Video Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
