SOURCE: MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
sounds like the fan element this link will help http://www.ransomspares.co.uk/elements.asp?search_fd6=XOU252
SOURCE: AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
SOURCE: Belling XOU252 Single Oven Trips Fuses Repeatedly
Hi.
Probably a faulty element, if you feel competent enough, disconnect the feed to the elements in turn, this should eliminate the problem.
Good luck.
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
