Sorry I do not know your machine.
I will tell you most I have seen is on the back of the machine. I think that is because the back of the machine is usually near the wall outlet.
Testimonial: "Hi Kenneth, Thanks very much for that tip. You were right. It was near the bottom near the back of the bike. I must be going blind. Graeme"
SOURCE: I need an owners manual
Vital Fitness
Customer Service
5988 Peachtree Corners East
Norcross, GA 30071
888/337-2883 M-F 8-4:30 EST
Manual has assembly/maintenance instructions and a 1-page description of functionality. And a warranty card...that is printed on the back of the instruction page. *headslap*
kb
SOURCE: Need Manual for Vital Fitness Exercise Bike RB26S
I have a manual for this model. I can not tell you how to find one, I have looked all over the net for additional info. on this model and can't find anything. Would be glad to scan and send you a copy if you still need it.
SOURCE: I have an Edge 491 Exercise bike and the control
Take a look at the battery compartment under the panel (left looking up). I had a similar problem and had just fixed it. Hopefully you can get the same results.
If the strip of metal with the spring is corroded, take the batteries out, and carefully remove the metal strip. I used metal duct tape and wrapped the piece of metal with the tape. Carefully put a slight bend in the middle of the strip and reinsert the strip. If the batteries do not connect up, bend the piece a bit more or add more of the metal duct tape. After doing this, the panel came back to life. If this is not your problem, then my apologies. If it is, then good luck.
SOURCE: Tectrix power bike 3000: power supply
TAKE THE SIDE PANEL OFF AND YOU WILL FIND A 6V @2.5 AH USE A MULTMETER AND IF IT CHECKS BELOW 6V THEN REPLACE
SOURCE: i need the power cord for a vital fitness exercise bike RB260.
If you need service or parts for the vital fitness RB260 bike call 888/337-2883 mon-fri 8 am-4:30pm (EST)
