Plumbing Logo
Question about Delta Plumbing
I have a delta 1016 tub faucet that turns on cold, then halfway around turns off and as you continue to turn them turns on hot water. It shouldn’t shut off though 1/2 way through turning the faucet...? How do I correct that issue?
Posted by Eric Kelley on
john h
    Top Expert:
  • Delta Master
  • 28,849 Answers
Turn off water supply and in you install sheet will see how to adjust the valve --remove the center handle and will see a blue and red stops need to move them to adjust hot and cold mix
Posted on Apr 08, 2020
  • Delta Master
  • 19,166 Answers
That model number is the beauty trim flange and not the actual faucet.
Posted on Apr 04, 2020
5 Related Answers
dragonsthatk
Albert Getty
  • 547 Answers
SOURCE: Bath tub faucet will only run hot.
if the hot comes out when you first turn on you have hooked up hot and cold backwards
Posted on Feb 12, 2009
Anonymous
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
Anonymous
  • 35 Answers
SOURCE: Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Posted on Feb 23, 2010
Anonymous
  • 349 Answers
SOURCE: Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Posted on May 05, 2010
Mike
  • 4383 Answers
SOURCE: When turning on the hot water on dedicated hot
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Posted on Oct 09, 2010
Brand new delta roman tub faucet. Cold works great and hot side is anemic. All new pex tubing feeds it. When I got it out of box both faucets worked counter clock wise to open hot was anemic then. I pulled...
Cna you remove water line feeding hot side to make sure it has correct flow. It could have something blocking inside of water line. And check hot inlet side on faucet to make sure it is open and not blocked.
Remove line you can run water in a bucket to ensure that hot side water line has no blockage in it and have someone help you with turning water off and on for you.
1helpful
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
6helpful
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Adjust the hot & cold water for delia monitor 1700
Remove handle and check to see if there is a dial to take out to repostion back in to adjust cold and hot water flow. take it out and move it a little put handle on and turn on see if it changes,
May 05, 2010 • Delta Home
1helpful
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
1helpful
Delta tub tap only cold water no hot water or pressure for shower.
take handle off and adjust the nylon set ring it is to prevent kids from getting burned and is probably set wrong youll see teeth and a pointer just pull it out a little and turn it in the oppisite direction then push back in
Kitchen faucet won't turn all the way off
You need to replace the washer on the stem. It's a Delta so it's possible that you have the type where the washer is actually in the very bottom of the manifold instead of on the stem.
Top Delta Plumbing Experts
David Shaub
john h
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
