Question about Home
Eco Flush. Why does it keep running? - Home
Posted by David on
Why does the formost single flush toilet run every once in a while??
It sounds like your flapper is leaking slowly
Apr 18, 2014 | Home
Hi I have a citizen eco watch and it will not stay with the right time have to keep setting it I havent worn it in a while so could you please tell me whats wrong
Your watch runs on light, you need to leave the watch under a light source for at least 18 hours, then as long as your wearing it, it should keep running if you are exposing it to light. At nighttime for a couple nights leave it under a light, so it has a good charge and keeps running. If this does not work then you need to call Citizen Watch repair at 1-800-321-1023.
Sep 16, 2011 | Citizen Eco-Drive watch
A picture or instruction on how to flush the cooling system on a cheverolet blazer 2000? Cheers
Easiest way to do this without the proper machine is to disconnect the return hose from the heater core. Then just start the truck up, and run fresh water through the rad fill cap, until all of your antifreeze is gone, and just water is coming out. Then top it up with antifreeze and your good to go.
Mar 26, 2010 | 2000 Chevrolet Blazer
I have a Citizen Eco drive waterproof wrist watch with four buttons and no ''winder'' can I get instructions for this watch
The eco drive means that it charges the battery using artificial light or sunlight, there is no need to wind as the battery never runs out of charge providing you keep it in light.
Oct 19, 2009 | Citizen Eco-Drive Aqualand BJ2004-08E...
Fisher & Paykel intuitive eco - code 12 Water keeps running and I have to keep turning of the machine and water supply. Please help!
The solenoid on one of the fill valves, in the washer, is probably stuck open. Only fix is to have it replaced.
Jul 11, 2009 | Fisher Paykel Eco IWL16
Home Logo
67 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
