Question about Samsung i85 Digital Camera
SOURCE: Can a lithium ion battery be overcharged?
Here's a small FAQ I found: 1) My lithium ion battery is the SONY NP-FP70 Battery Pack. Does the fact that the battery is called a battery pack mean that it has built in circuitry to prevent an overcharge? No. I write with some authority since I've dissected too many and there is no such circuit in the battery. From a system perspective it doesn't belong there. 2) Is there any way of knowing if my SONY BC-TRP charger has the circuitry for preventing an overcharge? You'll have to ask, but the key clues are: a. The documention tells you to not leave it plugged in overnight. b. The battery gets too hot and melts the plastic. 3) If I charge my battery in my camcorder (SONY DCR-HC40), can I assume it has the built in circuitry to prevent an overcharge? a. One can't assume anything. b. But from what I read on that model, you plug it in and forget about it. To do that, it would have a proper charge circuit.
Posted on Sep 13, 2005
SOURCE: Wont turn on
your all in trouble.. im on my third one..a pro surfer/shaper... you must wast it completly with fresh water immediatly after leaving the sea.. the chrome corrodes within hourd and allows the seals to leak. also sand etc gets stuck in the lense door...
Posted on May 25, 2008
SOURCE: Battery charger(BC-11L)
Battery charger will not hold its charge. the red light keeps blinking
Posted on Oct 09, 2008
SOURCE: Cant charge my battery
i have same camera.. but i dont think this is a problem.. while charging light keep flash.. when it completes charging it shows u solid red light..
Posted on Dec 27, 2008
SOURCE: There is a yellow blinking light on my Black jack
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II charging problems
Posted on Jul 27, 2009
