Question about Sony Televison & Video
My sony Bravia 47"clicks off and on about every 5 min. Can you help? My set built in 2006.
Model # KDL-46S2000.
Posted by Ken Killam on
John Diles
    Welcome Back:
    Visited the website for 2 consecutive days.
Problem is a bad capacitor on the power board. Caution if repairing yourself as capacitors in TV's hold a charge long after set is powered off and can be lethal.
When looking at your power board for a bad cap look at the top of the capacitors. A bad cap will have a noticable "bulging" on the top of it compared to others. Be sure to note polarity of capacitor (will have a "-" on one side indicating negative. To fix on/off issue simply unsoldered bad capacitor and solder in a new one with same voltage and capacitance rating being sure the new capacitor is oriented the same as the old one was before it was removed.
Posted on Mar 31, 2020
5 Related Answers
Anonymous
  • 131 Answers
SOURCE: Sony Bravia XBR 47
They are getting ready in august to lunch a new tv.Thsi is the time of year you will get the best eals on tvs . the 2009 come out in the fall.
Its a great tv you got dont worry thanks doctor video
Posted on May 18, 2008
tvhelp-Dave
Shukai Fung
  • 178 Answers
SOURCE: I have a Sony KDL-40V4100, constantly hearing clicking noises
Could be the power board or main board defective, but I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 download the software.
Posted on May 09, 2010
Testimonial: "I will try to update the firmware. Thanks !"
Anonymous
  • 5 Answers
SOURCE: I have Sony Bravia BXR
Is this problem happening on all sources (dvd,cable box,etc.) .Try to isolate the problem to one source and then proceed to check the interconnects involved. This sounds like possible a HDMI issue from the cablebox or sat box, but im not sure how your system is hooked up
Posted on Aug 18, 2010
markfreedman
Mark Freedman
  • 312 Answers
SOURCE: have a 2006 Sony LCD Bravia 46" TV. Receipt from
I don't know the relationship that Cosco has with their customers however the best way to get the CORRECT model number is directly off of the back of the TV. The model number you have is not complete. It should have something like a "KVR" or at least something beginning with a K.
Hope this helps,
Best Regards,
Mark
Posted on Jan 26, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: sony bravia 40cx520 jump button
download your owner manual and read very well
the specification and proceed with your requirements
www.fitness.manualsonline.com
God bless you
Posted on Sep 25, 2012
How much cost to repair vertical color lines on sony bravia 46 tv
Please confirm if your model no. is KDL-46s2000 to assist you further on your problem.
Oct 05, 2011 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My Sony Bravia KDL-46s2000 has sound, but no picture. I have been told that it is the Digital Video Driver board that has the problem, i have also been told that the fuse for the driver board needs to be...
chances are you either have a bad main bd (bu) or you have a defective inverter, or it is pssible to have a bad panel.
you definitely need a technician to look at this.
Oct 16, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I am having an on and off again problem with "no sound" just a picture on my Soney HDTV Model # KDL-46S2000. I have Verizon Fios and they have been out several times to try and fix the problem by changing...
when the sound goes out again ..try connecting a dvd with the same wires and input ...this will let you know if it is a tv problem ...and if it doesnt go out ...when you do this .. verizon need to check the sunrise readings to your set top box
May 20, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My lcd flat screen plastma tv screen got broken.i want to know is is repearable.
KDL-46S2000 Panel cost approx $1500 +$3000 core charge, Part # 1-802-100-31.
Parts reference: Andrews electronics, 800 289 0300.
May 08, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
The vertical screen cannot be adjusted. Watching football games the score cannot be seen at the top of the screen. changing vertical center and vertical size has no effect
You question shows its Sony KDL-46S2000 lcd tv so adjust screen format like zoom etc to adjust picture size best fits in screen.
Screen format option is available in Menu.
Dec 06, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
NTSC to Pal
it will not work with PAL, and I am not aware of a PAL converter. Sorry.
May 24, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Troubleshooting
8 flashes indicates a main processing IC on the video process board has failed You will need to have the BU board replaced.
Jul 27, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Televison & Video Logo
314 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
