Question about Philips Audio Players & Recorders
Philips d573 mini audio hifi system, suddenly display going off, how to fix the problem ?
Posted by paul on
Tom Chichester
    Top Expert:
  • Philips Master
  • 57,306 Answers
This can be due to a bad connection such as a cold solder joint or eventual failure of the display element.
Posted on Mar 31, 2020
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Scott ZXP8 Eclipse cd mini hifi system
Was the fuse Blown?? check with an ohm meteracross the two prongs that you plug into the wall of course you gotta unplug it for this. It should read around 4 to 10 ohms depending on the type of power transformer is in the unit.. If it reads open then theres a fuse open or a bad power transformer. If its not open check the power supply for the proper voltage from the diagram. Good luck
Posted on Apr 16, 2006
Anonymous
  • 71 Answers
SOURCE: Kenwood XD V757 System Protected
check the speaker wires are not shorting out
Posted on Dec 17, 2008
Anonymous
SOURCE: i've sony mini hifi MHC-GZR88D. flicker
cold reset your hi fi system, by powering on your system then while holding stop button press disc 3 and power at the same time.
Posted on Apr 12, 2010
Ironfist109
Iron
  • 3018 Answers
SOURCE: I'VE PHILIPS D573 DVD HI
Your disk could be scratched. You can try and resurface it. You may try to clean the disk as well. Also if a burned the DVD some players will not play every format. Are you getting the same response from several DVD's? If so then I recommend getting a good DVD lens cleaner disk and running it through a time or two or even three if it has been a while since it has been cleaned. Good luck.
Posted on Mar 06, 2011
Ralph Snijders
  • 50 Answers
SOURCE: got a sony mhc -grz88d mini hifi ,the display just turned off ,it cannot switch on,how can I fix it
check the fuse on the inside.
Posted on Nov 03, 2016
Why is my LG mcd503 mini hifi displaying protection when turned on?
caps in the switch mode power supply replace the swollen caps and good to go.
Jan 04, 2017 | LG Audio Players & Recorders
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
Need a remote for a PHILIPS Mini HiFi System
Try E bay as the remote is considered an accessory and are one of the first product to run out of supply. There is always the possibility that a person will sell one from either a shipping damaged unit or one that could not be repaired but the remote still works.
Jun 02, 2012 | Audio Players & Recorders
I'VE PHILIPS D573 DVD HI FI MINI SYSTEM WHEN I INSERT THE DISC IT IS NOT WORKING GIVE INDICATION THAT NO DISC
Mar 06, 2011 | Audio Players & Recorders
How to connect MHC-RG222 speakers to my pc
If you have an output function at the back of your mini HIFI then surely you can.What you need is a Dual RCA [from the mini HIFI] to 3.5 mm Stereo Jack [to the PC]. The cable is easily available in the market...go to this site n you'll get the idea http://www.vpi.us/cable-audio.html
Jun 17, 2009 | Sony MHC-RG222 CD Shelf System
Can get mini hifi system to work with tv and dvd player. How do I connect them?
To be honest mini hifi`s arent the best to be using as speakers for your tv.
But you connect them using RCA phono cables.
Its a lead with a white and red connector on each end.
Lokk up RCA phono cable and you`ll understand what i mean.
You plug that into your tv then to hifi,
May 31, 2008 | Philips Audio Players & Recorders
Mhc-gnz88d (sony hifi DVD System)
5e592bd0-46d6-403f-ab4a-21969e3345d5.jpegI have a SONY MHC-GNZ88D Mini Hifi System. Everytime problem while play a CD or a DVD. The problem display "DESK ERROR". CD & DVD working but Next, Fwd, Stop etc buttons are not working.please help me.
My cont number - +91-9031257594 Nazish
May 21, 2007 | Sony Multi-System Mini Hifi Systems / DVD...
100 people viewed this question
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
