SOURCE: I did a factory reset of my tcl roku 42" tv and all tiles were removed. How do i get them back?
When you do a factory reset it eliminates everything and restores unit to the way it came out the box.
You need to go through the set up procedure from scratch with passwords, etc so unit will then download the tiles from your roku account. Check under the settings section to see if you have a listing there for resetting up. If not contact support at TCL and they will tell you what to do.
SOURCE: My 42 inch tcl roku smart tv is making a popping noise sometimes what does this mesn
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Use remote button to change channels - check manual for directions.
