Question about The Kitchen Appliances - Others
When I put the kettle on an push the button it beeps and doesn't heat.
Posted by Kristine Bromberek... on
john h
    Top Expert:
  • The Master
  • 23,504 Answers
Switch or element failure
Posted on Mar 30, 2020
Attique-ur-Rehman
    Top Expert:
  • The Master
  • 2,677 Answers
Https://www.youtube.com/watch?v=QdaiVazKmYQ
It beeps and the temperature light comes on but then it immediately fades and the kettle does not heat up.
I had the same problem after 2 years usage and found the problem to be the contacts between the kettle and base.
  • Unplug the base and using a very thin needle file clean the 3 contacts and centre pin carefully. These contacts are sprung metal, so be careful to apply slight pressure in a clockwise direction.
  • Next empty and upend the kettle, now use a fine abrasive pad (I used a piece of 'wet and dry' paper) and gently clean the surface of the contact rings.
  • Clean away all dusty residue, this should cure the problem.
Jan 13, 2016 | Bosch Styline Collection Kettle Twk8633gb,...
I have a Cuisinart CPK17 won't heat water and all the blue lights are flashing
I had the same issue with all lights blinking, but nothing else working (buttons would not respond or beep). I took the base off and used a small pair of pliers to bend the contact as Scott Cowen mentioned. Worked like a charm.
Jan 07, 2013 | Cuisinart CPK17 Electric Kettle
The warming button is stuck in the "on" position.
Push down on it toggles it on and off. Push down on it and it will release back up. Hope this helped...
Jan 11, 2011 | Oster 5965 Electric Kettle
It won't turn on when I push down the switch. It worked perfectly minutes before.
Ultimately, how I ended up fixing my Oster 5965 and Hamilton Beach Cool Touch Electric 40898 kettles that had the same problems as you (Nothing would work; no heat, no buttons would light up) was by taking apart the bottom screws (Be warned, for only one screw I needed a "Spanner Insert Bit"). I jiggled the connectors as I rang them out with my multimeter and everything seemed to work. Leaving the bottom off I retested the kettle and it just worked. I reassembled the parts and made my happy wife a cup of English Tea.
Sep 28, 2010 | Oster 5965 Electric Kettle
HD 4651/C Electric Kettle Handle switch lights but wont heat
This maybe the thermo fuse, and or the heating element that is defective. These parts must be properly replaced for safety issues.
Usually these appliances are not worth to service.
Jerry G.
Apr 07, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
66 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
