Recover a Deleted Recording from Your X1 DVR
https://www.xfinity.com/support/articles/x1-recover-a-recording
SOURCE: Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
SOURCE: how to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
SOURCE: have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Testimonial: "though unfamiliar with unit, pob-h tried to help solve my problem! that's more than i can say about my own husband! thanks for trying!"
SOURCE: Dvr not working. Won't record, pause rewind
Try unplugging the unit from the electrical outlet for about five minutes- much longer than required- and try it again. If this fails you will need a service technician to resolve the issue. Thanks for using Fix Ya.
SOURCE: purchased astar dvr-2100 dvd recorder. power button
Can you be more specific? Is there anything on the display? Or is the red power light on or off? Some more detail is needed.
Testimonial: "no power at all. unit does not respond. power lite does not come on."
