Question about Coleman Electrical Supplies
I have a Coleman Vertex 7500 generator. It does not have a battery installed, so I jump start it. As soon as I take the jumper off, the engines dies. Any Idea why?
Posted by Brandon Wood on
I HAVE A COLEMAN VERTEX 7500 PORTABLE GENERATOR, AND THE BEARING IN THE END BELL OF THE ALTERNATOR IS NOISY. WHERE CAN I ORDER ONE TO REPLACE IT ?
Check the sears parts site with your model number and get a part number, then search with the part number for the best price....
Sep 19, 2018 | Coleman Electrical Supplies
Coleman vertex 7500
The capcitor needs checking in the end of the alternator
Oct 03, 2013 | Electrical Supplies
PM0557523 7500 WATT Vertex Coleman missing Capacitor.Need a wiring Diagram for AVR.0065649 Board I have a new capacitor comming and new Diodes.but I dont see where the wires conect to the AVR board?!
There are at least two AVRs for this generator. The original AVR has the diodes mounted on an external heat sink. The updated AVR has the diodes mounted directly on the circuit board. I have a schematic of the original model with the external diodes but it doesn't have the values or parts on the schematic. I will be more than happy to e-mail you a copy of what I have.
Oct 26, 2011 | Coleman Powermate Powermate 5000W...
Vertex 7500 not generate energy
Have you let it set for a long period? I have heard that if you do not use a generator that it will simply stop working(generator portion itself). Make sure no breakers are tripped and the wiring looks OK.
Sep 26, 2010 | Coleman Powermate Powermate 5000W...
Take off jumper cables it dies
You're alternator is dead. Once started the alternator should generate enough power by itself to keep the engine running.
Jul 06, 2010 | 2001 Dodge Intrepid
No output voltage at all
The generator needs to be 'flashed' to bring back the excitation for output. Is this something you can do? Let me know and I can help you...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 10, 2009 | Coleman Electrical Supplies
I have a Coleman Vantage 3500 motor runs no generator output
This sound like a loss of residual magnetism in the generator. The field will need to be "flashed".This is also known as re-exciting the field of the generator.
The Coleman manual gives these steps:
1Use a 6 Volt lantern batters (dry cell) or a 12 Volt automotive battery.
2.Disconnect all loads from generator.
3. Remove the brush cover (that's the rectangular plastic cover on the end of the generator.)
4. Plug a lamp or light into the generator before starting the engine. The light will illuminlate when ?Voltage has returned.
5. Start the engine with no load connected to the generator.
6. Attach the "-" lead of the battery to the negative brush. Very briefly touch the "+" lead of the battery to the positive brush. Remove as soon as Voltage builds up.
Sep 02, 2009 | Coleman Electrical Supplies
Electrical Supplies Logo
74 people viewed this question
Top Coleman Electrical Supplies Experts
Sheldon Dedek
MrJunk
Level 1 Expert
Tim Venetis
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
